I´ve been playing 3 different amps/preamps lately. First up was a JMP-1, than a modded JMP-1 and today a got a modded SL-X head. This is within 2 months... :roll:
Anyways. For a long time I was playing Pod XT Live as a preamp with my EL34 power amp. Sounded ok and than I bought a Samson 15 band rack EQ. My Pod sounded great! Same think with my first JMP-1. Did put the EQ in the loop. The EQ did a HUGE difference. My second JMP-1 also needed the EQ n the loop.
Today I thought I wouldn´t need my EQ or my TS-9 anymore. Wrong. My EQ is the think that makes my sound. Without it my sound is thin and don´t cut through as good.
I use my EQ to boost the mid. I did try to put the EQ before the preamp on my second JMP-1 but it sounded like I was playing in a can or soemthing.
I´m about to buy my self the MXR M108 EQ pedal to use as a midboost infront of the preamp. Still gonna keep the EQ in the loop. The EQ pedal might replace my TS-9. Might...
I think if You want more gain than You should put the EQ before the repamp. If not, put it in the loop. Don´t buy a rack EQ and put it before the preamp, use a pedal for that.
