Author Topic: Argh help me with my playing! :o(  (Read 4546 times)
chrisola
« on: July 26, 2006, 01:03:13 PM »
Ok so i'm playing again, and feel fine.
HOWEVER.
I'm having a weird problem when playing notes on the G string and b string
i'm learning a solo that has a slow sweep in it... which is fine, its the 1st thing i've managed to sweep properly and smoothly.
Happy maybe?
NOPE!!
Heres the pattern:
|-15p19p15-------------15----20p15------------15---|
|--------------17-----17----------------17----17-------|
|------------------16------------------------16---------|
Problem i have is that the note on the G string comes across as noise rather than a note. No matter clean (even worse sounding) or distorted, alternate picked or sweeped, downpicked etc. The faster i try and play it the worse it sounds.
It kinda 'barks'.. hard to explain...Instead of just the 'note' its got a kinda overtone 'doop' type noise... i've made a small clip of the sound (save image as.. and rename to .mp3)
I also get this when doing pull offs eg
|-12p9-------9--12p9-----9---------|
|--------10------------10------------|
Seems more obvious on those types ^
Anyone offer any advice?
Even played slow i still get the sound... is it the guitars setup? Strings dont buzz\catch and i get it on my Legra and my Dean.
If i palm mute the offending string even slightly then it sets if off even worse! .
Am i just being strange or does it sound wrong???
Thanks for any advice\tips (before i hacksaw my guitar up)
« Reply #1 on: July 26, 2006, 01:21:43 PM »
Pickup heights to high, choking strings?  Or too much neck relief?  That's all I can think of.
chrisola
« Reply #2 on: July 26, 2006, 05:22:12 PM »
or i'm shitee  :cry:
 :D
deg0ey
« Reply #3 on: July 26, 2006, 06:57:24 PM »
You get it on 2 different guitars?
What amp are you using? Maybe the amp doesn't get on with notes of that frequency for some reason?
chrisola
« Reply #4 on: July 26, 2006, 09:06:00 PM »
line6 guitar port...
i think maybe BOTH need a setup...
it cant just be my playing.. i'm not playing one note harder than the others... how strange  :?
deg0ey
« Reply #5 on: July 26, 2006, 09:49:36 PM »
Mmm maybe they need setting up, but I wouldn't think that they both have a dead spot in the same place...
