single coil grounding
Started by Michael A Porter, July 27, 2006, 07:17:36 AM
Michael A Porter
When you're grounding a single coil pickup in a sheilded guitar should you still put the ground to the bridge or on the shielding tape?  I'm asking because for some reason I think somewhere I had read that you want to ground them to the bridge.  If this is the truth why?
gingataff
I thought the ground would usually go to a pot casing, which is in turn grounded to the bridge and the body shielding. Perhaps I'm wrong.
I see a rainbow rising
Look there on the horizon
And I'm coming home
Michael A Porter
well i meant from the pot but yeah where it goes from there im not sure.  for some reason the random bits of information ive read have just confused me.  is anything even different when dealing with single coils?
DeanS
Pots are grounded out to the claw plate on a trem bridge version with some Fender versions having a second ground wire, see below
http://fender.com/support/diagrams/
Mothers Milk set, VHII
deg0ey
You wanna be careful to avoid ground loops though - If you ground something twice terrible things can happen...
The main example of this is that if your shielding connects the chassis of the pots to each other (which it should) and then you have a ground wire running between them, it's a bad thing. I forget why it's a bad thing, I just remember that it is :lol:
