Quote from: DakineAnyway, maybe ya need to be a 'guineapig' and try for us all :)
Thanks for volunteering me!
If I had the know-how, I might give it a go. Problem is, if you destroy a set of cheap hardware it hasn't cost you much, but if the process works you're left with a nice-looking - but cheap - set of hardware you wouldn't want to put on a quality guitar.
Conversely, if you use quality hardware and wreck it that's money down the drain - and even if the treatment works on the finish, it sounds like all that heat might have a detrimental effect on the tone(?).
I know next to nothing about metallurgy, but wouldn't there be a problem that the bridge material itself - probably cast brass in the case of modern Gibson parts - would be affected by the heat at a much lower temperature than the chrome plate? Even more so with lightweight aluminium parts. Or does the thinness of the chrome plate make that less of an issue? :?
This is making my brain hurt... but it's interesting.
