Tough choice
Started by Hammurabi, June 07, 2005, 05:52:12 AM
Hammurabi
I need new pickups, but I have no idea what would be the best choice for them. The problem is I'm in two very different bands. In one of them I need to play about as clean as possible. Think acoustic sim. In the other band I need to play about as heavily as possible. If you've ever heard System of a Down's song "BYOB" that's exactly what I'm looking for.
Being a college student I don't have much cash to throw around. I only have one guitar (mahogany neck and body, 2 humbuckers) and I can't afford to buy another. I only have enough $ to replace my currently sucky pickups. So, what would be a good pup combination to best satisfy both needs?
HJM
VH2s would be a great starting point. Good clean tones and enough power to get things rocking without too much effort on your part. Tap the coils for some great strat/tele like tones. Works a treat on my old PRS.
You could go for a Nailbomb, that's about as far as you'd want to go if clean tones are a priority.
Go for Alnico over ceramic. The splits will sound sweeter! :P
Tim
Ditto.
Also worth considering is a Warpig.............this humbucker is seriously heavy when used in series but split it down or run in parallel and it's crystal clean.
Welcome to the forum!
Tim
Hammurabi
So would a VH2 neck/Warpig bridge work well together?
HJM
Might do, but if I was going for a Warpig bridge, I'd get one for the neck to in a calibrated set, then wire the neck in parallel as Tim suggests. Parellel wiring is a great half single half bucker type tone, great for clean tones.
Do any of the clips help?
OrangutanShoes
This whole parellel thingy for the neck pickup has me quite interested. What does it sound like with distortion? And does it affect the tone of the bridge pickup?
Hammurabi
QuoteDo any of the clips help?
Some of those clips are pretty impressive, but I didn't find any humbucker clips with much clean chord work or anything like System of a Down. It seems everyone here has better taste in tone than what I'm lookiing for.
HJM
It kind of gets straty but without the noise, best way I can describe it.
It doesn't effect the bridge, unless you parellel wire the bridge too, it's just how you wire up the humbucker coils.
It's either the Nailbomb or the Warpig, I think. To be honest, I think the Nailbomb would get you closer to the SOAD sound than the Warpig. SOAD isn't half as bassy as it might seem and their clean sound is very jangly.
