Neck Pickups (Question for Tim)
Started by JamesHealey, July 29, 2006, 09:58:25 PM
JamesHealey
Cold Sweat and Miracle Man,
which pickup has the less bass? and which has the less output?
and which one has the most mid range?
Cheers..
I can answer those questions.
Quote from: JamesHealeyCold Sweat and Miracle Man,
All things being equal, using a clean setting, the Cold Sweat has more   low bass and lower midrange.  Overdriven, the Cold Sweat has even more bass, lower midrange, and midrange, with a slight rolloff in the high frequencies. With the Miracle Man, there is a rolloff with the hig freqs as well as the upper midrange.
Quotewhich has the less output?
They both have the same perceived output, to my ears. However, I classified the Cold Sweat as being more 'driving', while I think that the Miracle Man is 'tighter'.
Quoteand which one has the most mid range?
Both pups have virtually the same amount of midrange push in the neck position. Subjectively speaking, the Cold Sweat has more air, upper frequency push, and harmonic detail in the neck position.
So, to sum up:
In the neck position --
Less bass = Miracle Man
Less output = n/a
More midrange = n/a
Hope that helps!
