Valve Amp Question
Started by Dakine, August 09, 2006, 06:00:17 PM
Dakine
OK, very busy/tired here (still lots going on after father's passing and mum has been ill too) so need some advice.
Was playing earlier and amp made a kinda 'pop' and the 4th gain channel now seems iffy.
It is a 50w ENGL Screamer head.
Basically 4 channels.
Now the fourth button which turns on 'clean lead' always acted as the 'gain/boost' channel with MEGA distortion and volume when depressed. Well now I can still hear distortion but the volume actually decreases measurably when it is activated/depressed.
This is my first valve amp and am busy/tired (as already mentioned). Any clues? Has a valve/valves given up? It is not old but bought it second hand (was told previous owner bought it new bout 4 months before I bought it). Basically just wondering what is/could be before have to take it to shop.
Thanks,
Nick
maliciousteve
A similar thing happened to me when i was testing a screamer combo. I was just playing about and all of a sudden i get no sound what so ever. Changed the tubes etc but still it was buggered. I never knew what it was in the end but i've heard that weird problems like this have happened to alot of the ENGL range. Including the SE, which a member from the band Fell Silent uses and he has had to take it back to ENGL over and over to fix the problem.
if the switch isn't doing what it's supposed to then I'd guess that the relay it controls is duff.  shouldn't be too much to figure out by a half-decent tech.  the main trouble with modern amps is how much cr@p they cram on the pcbs and having to dismantle half of the amp to get to anything (pcb-mounted pot rant over).
:twisted:
Dakine
Umm, ok.
So, don't think a specific valve may have gone then?
^ it depends. is it the high gain versions of both the clean channel and the lead channel that sound cr@ppy?
Quote from: DakineUmm, ok.
when a specific function is not working on an amp it's generally not valve related. take it to a tech is my advice.
:twisted:
Dakine
Bit of a 'need to know how stuff works' kinda guy (tis my nature,can get me in trouble,why worked with Police in Texas 'good guy btw'). Anyway, got it working again :)
German well made in fact. Good stuff, long as it behaves now :)
so what was wrong - what did you do to fix it? was it an intermittent problem that has fixed itself?
:twisted:
Dakine
Thing is sooooooooo brutal it had a bad electrical connection (distorted itself loose), plug connection. To be fair it has been moved around and had a slight knock. Anyway, brutality returns :)
^ awesome, glad it's worked itself right, nick. \m/
