Valve Advice
Started by LiamH, August 13, 2006, 08:19:57 PM
LiamH
I have a Laney LC15. I think it is a great little amp. However, I have one problem, the valves hang upside down and as such they have been fitted with a little retaining clip. A couple of the clips do not wrap snuggly around the valves and when I hit low notes they have started rattling like mad.  Laney's advice was to crimp them or buy new ones. My question is: do I need them at all. My amp does not move from my dining room and to me the valves are pretty snug and secure without the clips. Do you think it would be ok to remove all the clips?
Taking responsibility takes all the joy out of life, and drains a man to dust
I have a VC30 and I get the same rattle that you do. I have moved the retaining clips but it doesn't seem to make much difference.Other than that, great amps for the money.
Fourth Feline
Hi Liam,
I would remove the retaining clips. I have three amps where the valves hang upside down and do not have retainers on some or all of the valves and all have been fine.
As you said, the valve pins  are usually tightly held by the valve bases. The only minor exception I have is a little Peavey Classic 20 where I can sometimes knock the valves a bit when lifting the mains lead out of the back. Even there, it is simply a matter of checking all is well before switch on.
To re-assure you big time, I can confirm that my (mighty) Fender 'Twin' has always had the four power output valves hanging upside down AND has been gigged a lot. They never fell out or got loose.
Regards,
Derek.      :D
LiamH
they are great amps I agree. I am going to have a word with Watford Valves, seems to me those chaps know their onions.  Will report back if I get a solution.
LiamH
He he, Derek to the rescue. Thanks a lot. BEGONE DAMN RETAINING CLIPS !!!! :)
Fourth Feline
I agree on both points:
Laney make nice amps ( I have a LH50R head )
and
Derek at Watford valves knows his stuff.
:D
I had a problem with a valve in my amp, it had a shoddy rectifier valve that buzzed with too much bass.  It didnt have clips so i knew it wasnt them doing it.  Quick change of the valve and all was sorted.
