Author Topic: Tim Anyone is this possible  (Read 3826 times)
  • Truly bad since 1972
« on: August 17, 2006, 10:47:49 AM »
want a single coil say a mothersmilk, inside a humbucker metal casing(so I don't need to mess with trying to find a new pickgard(as is non standard)...also if poss as well angled inside said casing like most bridge fender singles are?
Sifu Ben
« Reply #1 on: August 17, 2006, 04:21:24 PM »
I did see this done once, only it was like a block that the (angled) single fitted in, rather than a humbucker case.
OD-Black_Fire
« Reply #2 on: August 17, 2006, 05:33:32 PM »
I'm positive it can be done, like what Sifu Ben said. I've seen them like that too it should be simple to put on a cover.
Davey
« Reply #3 on: August 17, 2006, 05:38:33 PM »
i shot a pm to tim a few weeks ago about this..
basicaly.. it would be VERY dificult to mount it onto the cover.
« Reply #4 on: August 17, 2006, 08:08:21 PM »
what not even straight like in a missipy queen cover say?
CaffeineJunkie
« Reply #5 on: August 17, 2006, 08:12:10 PM »
couldnt you just put in a dummy bobbin next to the single coil????
« Reply #6 on: August 17, 2006, 08:12:50 PM »
yup can't that be done
Peter Antal
« Reply #7 on: August 17, 2006, 10:25:19 PM »
I think the coil shape will be different so it won't sound like a true single, if you use humbucker-style bobbins.
« Reply #8 on: August 17, 2006, 10:35:48 PM »
What about a humbucker sized mounting ring?  Allparts make them:
http://www.allparts.com/shopimages/PC_6643-028-196.jpg
Kilby
« Reply #9 on: August 17, 2006, 11:35:54 PM »
Quote from: Peter Antal
I think the magnets are different too
Rob...
Goodbye London !
« Reply #10 on: August 18, 2006, 10:48:03 AM »
Phil I think that might be the one for me thanks
