Author Topic: Apaches questions; wiring and polepiece recomendations.  (Read 3481 times)
Fourth Feline
« on: August 17, 2006, 09:46:26 PM »
Hi folks,
I am currently saving for a set of 'Apaches' for my Fender MIJ Strat '57 re-issue. Two big questions come to mind:
1 ) Should I have the middle pickup Rw/rp for hum cancelling in switch positions 2 and 4, or have it straight wired as I think I recall Tim saying that the 'quack' is much better if you forego the hum cancelling effect.
2) The fingerboard radius is 7.25, should I order the '54 stagger or a straight polepiece set ? I am only put off the '54 stagger as I read that it has  much lower polepieces underneath the top e and b strings - the very two strings I want to 'cut through'  better.
Before I ring Tim and ask what all you good people are tending to order, I wondered if you would give me some direct feedback/recomendations yourself.
Thanks in anticipation.      :D
Regards,
Derek.
« Reply #1 on: August 17, 2006, 09:57:04 PM »
If it is a 57 reissue, it presumably has a vintage neck in which case I would go for the vintage stagger. In all honesty I dont think the stagger makes a great deal of difference but would suit the guitar.
As for the RW polarity thing, I would ask myself how important the "in between" tones are- some players  never use them others do.Sorry it is not a helpful answer.
Fourth Feline
« Reply #2 on: August 17, 2006, 10:14:39 PM »
Just to clarify a point on the importance to me of the 'in between' sounds, I tend to almost live on the combined bridge / middle position.
Ta.
HJM
« Reply #3 on: August 17, 2006, 10:24:24 PM »
If you like RWRP in between tones and you're used to them, get a RWRP set. Stock has a different tone, more balls but looses a bit of the slightly hollow in-between sound that some people love.
« Reply #4 on: August 17, 2006, 10:31:48 PM »
There are 2 vintage staggers.  The 54 and the regular vintage.  The vintage stagger makes the top E & B lowest, then the bottom E & A, with the D & G tallest. The 54 has the G magnet lower and A higher.
If you get the regular vintage stagger you will be OK.
Fourth Feline
« Reply #5 on: August 17, 2006, 11:30:13 PM »
Thanks Phil and HJM, invaluable advice you have both given there. It is the " slightly hollowed out in between tones " that I love. The Telecaster and Gibsons can handle the rest...   Thanks for the experienced input.
HJM, I was pleasantly surprised to see a 'BKP meister'  here in West Yorkshire - there is chance for us tykes to yet become a cultural force then !
Also what type of guitar do you have your SMs in ? are they the Alnico II type ?
 :D
Regards,
Derek.
Elliot
« Reply #6 on: August 18, 2006, 08:29:11 AM »
Just to reiterate Apaches come in 54 or 56 vintage stagger - I think you want 56 if you are playing it safe to the 1957 strat spec.
Fourth Feline
« Reply #7 on: August 18, 2006, 01:17:11 PM »
Thanks for the timely warning Elliot, much appreciated.  :)
