my amp just stopped working?!
Started by JamesHealey, August 18, 2006, 03:14:20 PM
JamesHealey
It turns back on? but theres no sound all the tubes are light up?
anyone any ideas.. no fuse blew or anything just went kinda "humph" then stopped making noise..
JamesHealey
it's making a slight humming noise when it's turned on and vibrates slightly...
Output transformer possibly?
What make/model is it?
JamesHealey
Carlton Camel..
The company dont exist anymore and they're extremely rare..
Skybone
Have you checked the fuses?
The HT fuse may have decided to call it a day.
What colour are the power amp valves glowing?
It might be an idea to get it checked in to your local amp tech.
Bibble.
JamesHealey
it was the HT fuse.. is that the one inside the chasis?
I had a load of marshall slo-blo fuses left what ever they are.
Skybone
You should have 2 main fuses accessable from the rear panel of the amp, the mains fuse (a T2A on my Marshall), and a HT fuse (a T500mA on the Marshall).
Sounds like it might be an idea to book it in with the local amp tech.
Bibble.
If it was the HT fuse, that's usually a sign of a blown output valve or a dodgy valve base.
