coil select with 4 conductor
Started by Tim, April 02, 2005, 10:48:47 PM
Tim
If you're wiring a BKP humbucker with 4 conductor and want to be able to select the screw coil with a coil tap/shunt, wire black to hot of pot tag, red and screen to ground and finally green/white to tap/shunt. This way the slug coil is grounded out when the tap/shunt is activated leaving the screw coil active. Great for HSS setups when the middle coil is RWRP -you get another hum cancelling tone in pos 2 of a 5 way. Alternatively to select the slug coil in a tap/shunt wire red to hot and black/screen to ground, green/white to tap, this would give you non humcancelling parallel tone in conjuction with a RWRP coil of an HSS setup.
Tim
Baxter
Hi Tim,
Does'nt this reverse the phase of the whole humbucker pickup ??
Bax...
HJM
Yes, but it's in phase with the singles, I believe :?
Tim
As a humbucker, it doesn't matter which way the signal goes if the pickup is used on it's own.If you had two humbuckers on a guitar they'd have to both be wired the same so as not to be out of phase with each other.
In this instance the pahse is correct for use with a RWRP middle coil and the screw coil of a humbucker to hum cancel when in parallel-if you wire the other way around,red to hot, black to gnd and green/white to tap, then you end up with the slug coil and RWRP middle on in pos 2 in parallel with no hum cancelling.
Tim
