3 Channel Guitar Amp with Boost
Started by everton_fc, August 21, 2006, 07:08:16 PM
everton_fc
Looking for  3 channel guitar amp, similar to a Marshall TSL but ideally with a "boost" option on amp/footswitch so I can boost whatever channel I'm playuing through.
Anyone got any suggestions?
Thanks
CaffeineJunkie
get a boost pedal
(and you might want to avoid the TSLs and DSLs)
everton_fc
OK...
A) why avoid DSL / TSL?
B) what dual channel amp would you suggest?
CaffeineJunkie
i've heard a lot of bad stuff about them
what type of music do you play????
everton_fc
Anything from chilled little wing esque stuff right through to maiden/metallica and anything else in between like U2 type stuff.
I just want to get rid of aload of my kit, strip back to just an guitar, wah-wah and amp... not going to be gigging as much in the future so want to to have less kit, and ideally let my amp be responsible for the range of overdrives availalble and rely less on pedals etc etc
CaffeineJunkie
well...
if you can find one, a good JCM900 (ie SL-X version, the dual reverb one has buzzy overdrive apparently), or a JCM800 would probably do the trick
either that or a plexi head, but that probably wouldn't get you into metallica area without a decent pedal in front of it
Quote from: CaffeineJunkiewell...
Yep, the dual reverb 900 is cr@p.
Engl seem pretty versatile, as do Koch, but they are pretty expensive I think.
downfader
Theres nothing wrong with TSL/DSLs!  :?
Mesa and Peavy are great makes to have a look at! The Peavy 5150 head is a superb stalwart of rock and metal  :wink:
The more I learn the less I know!!
everton_fc
yeah i was under the impression a TSL would be a good workhorse, especially if I'm not going to gigging that often - what experience do others have of Marshall TSL amps? Do they sound good? Are they reliable?
Keep posting suggestions... cheers!
Check out the Splawn Quick Rod!
Ultimate hot-rodded Marshall tone, with solo boost for all channels.
^ or if you're in the UK, and don't have the cash for the quick rod, the laney tt would be worth a look (if by boost, you mean dual master volumes).
What's the budget for this investment?
Which style of music is preferred? How clean do you need it? How heavy do you need it?
Are you looking for 3 very different channels or 3 channels that are of similar type tone just different gain structure?
Which wattage is needed/preferred? Looking for a low-watter or an amp with muscle?
Head or Combo?
Reverb needed?
Will you need to use the effects loop?  Parallel or Serial?
JJretroTONEGOD
save up and get a mesa boogie! if you want amp overdrive and distrotion out of this world. It's the best option I think, some of them even have 5 channels each with it's own boost on/ff AND reverb switches all controlled via one pedal board/switcher. they're also extremley quiet, no hum at all. amazing!
JJretroTONEGOD
why not get a Mesa Boogie Mark IV? If you have the money money money (unlike me) then get it! ( I would ) PRECIOUS TONE, ahhhh.
Andy Lindsay
I'm selling my Engl Savage 120. 4 Channel with boost on each of 'em. £899.
