Poll
Which sounds best?
Wah.mp3
1 (7.1%)
Flange.mp3
3 (21.4%)
None.mp3
7 (50%)
Other (please specify)
3 (21.4%)
Total Members Voted: 12
Voting closed: August 21, 2006, 07:23:54 PM
Author Topic: OK, need another set of ears......  (Read 7748 times)
CaffeineJunkie
« on: August 21, 2006, 07:23:54 PM »
i'm in the process of writing a song, and i need to decide on one of these clips to use a base for the rest of the song
(i won't be using these clips, just using the style in each)
:D
enjoy...
« Reply #1 on: August 21, 2006, 07:43:57 PM »
F/x like wah and flange need to be really subtle and I would say to keep it simple- by all means use f/x but does it have to be all one thing or another?
CaffeineJunkie
« Reply #2 on: August 21, 2006, 07:46:16 PM »
nah, i'm just throwing ideas in to the air, and seeing how people respond to them
i'm not going to say publicly which one i prefer because that might sway the decision
as this is intended to be the first song for my band once i get it going, i want it to have a real impact, that's all
« Reply #3 on: August 21, 2006, 08:36:17 PM »
I prefer the flanger for that one, they all sound a bit weak in my opinion though.
Crazy_Joe
« Reply #4 on: August 21, 2006, 08:36:39 PM »
Out of those clips i thought flange was the best, but that was out of those clips.
In that kind of style i'd say the wah would be best, i just thought in that particular clip the wah didn't do much for me.
Try a chorus effect, or maybe a chorus effect with the wah.
Black Dogs
CaffeineJunkie
« Reply #5 on: August 21, 2006, 08:37:36 PM »
k, thank's for your input :)
JJretroTONEGOD
  • JJ Retro w/Mule + BKP90
fffflnage STUPID FAT HOBBITSIS!!!
« Reply #6 on: August 21, 2006, 09:29:27 PM »
stick with the flange, the wha is too pornofied and the dry is not exciting enough for me, but then again flange is my favourite effect out the lot. I think it's underused, I personally use the line 6 Liqua-Flange pedal, which is an outstanding pedal, the only snag is, it needs an adaptor. What pedals did you use for the flange and wha???
cheers,
from Ben.
CaffeineJunkie
« Reply #7 on: August 21, 2006, 09:37:38 PM »
the flange is built-in to my amp (cr@ppy AVT150X) and the wah is built-in to my effects processor (equally cr@ppy AX10G)
thanks for your input
« Reply #8 on: August 22, 2006, 11:29:50 AM »
I liked the one with no FX. The others sound a bit like porn music to me.
JJretroTONEGOD
« Reply #9 on: August 24, 2006, 12:41:35 PM »
Quote from: CaffeineJunkie
I may check the amp out, it actually sounds really good for a tranny (transexual) amplifier.
Fourth Feline
« Reply #10 on: August 24, 2006, 04:42:54 PM »
I would be tempted to try a little chorus.
I once had great success using chorus on an otherwise 'clean' Funk backing track. I played the rythmn parts slighty 'chorused' and then the lead part with the chorus off and a creamy sustain on.
If not that, perhaps a touch of compression and /or a touch of very short 'slapback' echo.
Otherwise, I liked 'None' the best. The material stands up in it's own right and needs to be framed not buried !     :lol:
Regards,
Derek.
CaffeineJunkie
« Reply #11 on: August 24, 2006, 06:09:09 PM »
Fourth Feline: yeah, will defs try the chorus when i get 30 seconds free time
JJretroetc.. : the AVT is fine, but don't turn it up, the only reason this sounds OK is because the line out is before the power amp, so the horrible solid-state cr@p doesn't screw up the sound, even tho there is still some, because there is only one preamp valve, so there will still be some solid state in there somewhere... the effects on it are kool, but they take some serious tweaking to get them just right, unfortunately mine isn't quite there yet, but hopefully it won't matter, as i am saving for my new amp now neway :D:D:D
PLEXI TOWN HERE I COME (i'll see you there bainzy :P)
cheers for the input guys
cjpmmd
« Reply #12 on: September 03, 2006, 05:24:54 PM »
[insert "Rain Man" voice]........The wah.....definitely the wah......
I like 70's porn music ---- it helps me pretend I'm younger, thinner, and actually attractive!
cjpm
