Author Topic: Delay Pedal and Effects Loop  (Read 7320 times)
Phantom_Orchestra
« on: September 20, 2006, 10:10:26 AM »
Hey guys,
 just got a Line6 DL4 Delay pedal, and not sure if im satisfied. im running it before my combo marshall, and it sounds like the delay aren't kicking in until after i stop playing, or if it does, sounds harsh and not smooth like the built in delay of the combo. just doesnt sound that great. i tried to put it in the effects loop in hopes it sounded smoother, but instead it decreased the volume of my rig. Is it just this pedal, or am I missing something? ive heard only rave reviews of this pedal so im a little confused anyone have suggestions on other multi-preset delay pedals?
thanks guys
« Reply #1 on: September 20, 2006, 10:55:53 AM »
You should use it up front, not in the loop.  That's where I use my delay pedal anyway.  Sounds like you need to tweak the settings to suit what you want.  Try shortening the delay time?
Brian G
« Reply #2 on: September 20, 2006, 02:49:35 PM »
I'm interested in this topic as well. I have a Rivera Fandango combo, with an effects loop with adjustable levels for send / return, so it's very versatile. I found my Boss DD3 sounded much cleaner thru the loop rather than in front, and no problems with levels. I haven't tweaked the levels very much, basically around 6 on both dials.
Most things I've read suggest that time-based EFX are better in the effects loop than up front, but there still seem to be varying opinions - depends on which amp, perhaps?
Brian
Another guitar product that I can play badly.
steve
    • http://www.cdbaby.com/stevegladman
« Reply #3 on: September 20, 2006, 08:09:00 PM »
I always use my delay pedal in he effects loop of my amp for many reasons- stronger signal, no horrible garbled delay when using over drive,
and i find it easier to control the overall delay level. Oh, and it sounds better to these ears.
Bainzy
    • http://www.shredaholic.com
« Reply #4 on: September 20, 2006, 10:38:32 PM »
The later in the chain the delay is, the better. Some people build slave rigs just to put it between the amp and cab.
catag
« Reply #5 on: September 24, 2006, 09:37:27 PM »
I found exactly the same problem with the Line6 units if its any consolation.
nfe
« Reply #6 on: September 25, 2006, 01:17:35 AM »
Likewise, i have a DL4 too, and in the effects loop of my triple rectifier it causes quite a significant drop in volume.
catag
« Reply #7 on: September 25, 2006, 08:53:59 AM »
As a general add on to all this, i have found very few fx which don't alter the base tone in some way although i accept one can get anal about it too. I have had a few quality amps in my time (Cornford MK50 and Hellcat, THD Flexi) and when you like the amp sound its a real pain. I wish i could afford Mr Pete Cornish's services. It seems the only real way of maintaining good amp tone! :?
everton_fc
    • Guitar Jar
« Reply #8 on: September 25, 2006, 01:46:32 PM »
I hear Robert Keeley does mods on DL4's to get over this issue - could be wrong though
http://www.robertkeeley.com/product.php?id=40
Kilby
« Reply #9 on: September 25, 2006, 05:31:42 PM »
Apparently there are some amps which simply dislike delay pedals, I remember Zachary Vez mentioned not using a delay with the Nano amp as it causes issues.
Rob...
Goodbye London !
Phantom_Orchestra
« Reply #10 on: September 26, 2006, 03:24:46 AM »
thanks for the many reply, very helpful. I  wrote an email to Keeley about the mod they offer; seems like it could solve the problem. Does anyone know of any other multi-preset delay pedals??
catag
« Reply #11 on: September 26, 2006, 11:18:57 AM »
http://www.bosscorp.co.jp/PRODUCTS/EN/DD-20/ is one off the top of my head. A lot of people use more than one pedal of the Boss DD3/6 Series too
