Main Menu
Toneport
Started by Shash, September 21, 2006, 11:52:22 AM
Shash
Hi I have a line6 toneport, basically my question is Im wondering how I can listen to myself while I play, I can record with it just fine, but I'd like to have a live feed through my pc speakers...   :shock:
I guess the alternative is to buy a set of headphones, but if there is a program out there which can allow you to amplify your voice live through a mic, the same principle should work if I switch the source to the toneport...
Any help would be appreciated.
Window-Licker
Problem is, they dont supply the correct cables, you need a small audio cable that fits into the "line in" of your sound card, and a 1/4 inch adaptor to plug that cable into the headphone socket, shouldnt cost more then a few £
Or like you said, you can plug in headphones, or connect the analog outs directly into your monitor speakers.
Best option which ive been using is the small cable, its basically the same setup they used on the guitarport, which i owned so luckilly i had the smaller cable type.
Peter Antal
You can also use the Toneport as the main soundcard and connect it directly with the speakers via the line outs.
