Nailbomb question
Started by Marco89, September 26, 2006, 06:19:14 PM
Marco89
Hey guys,
I'm new here, so I like to say Hi to everyone here. My english is too bad, but I'll give it a try..
Yesterday I recieved my Nailbomb witch I planned to put on the bridge of my Gibson SG special. I know how to put pickups in a guitar but.. I opened my guitar and it was wired strange but worked perfect. So I went on the internet and searched around, the wiring was standard Gibson SG wiring, but was totaly diverent than a standard LP wiring. The 2 pickups where soldered on the Neck volume pot or something. My first question: The LP and Sg are technicaly the same guitars. 2 pickups, 3-wayswitch, 2 tone and 2 volume pots. Why dous gibson do this, a diverent sound or something?
Anyway, I grabt my solder iron and changed the whole thing in a standard LP wiring (I understand how that works), put the Nailbomb in it. I checked it, and it worked. But, the thing is there is a volume diverence between the Nailbomb and the 490t I replaced. The 490t was a bit louder than the Nailbomb, I did not expect this. (it's a 2 conductor Nailbomb.) So I searched on the gibson website for the pickup resistance, but I couldnt find anything. So my second question is: Is this output diverence normal or a mistake I made somewhere in the wiring.
My Gear,
Gibson SG armed with Nailbomb
Mesa/Boogie Dual Caliber 3
Epiphone Sg
Peter Antal
Did you adjust the Nailbomb close enough to the strings? I have mine at 3 mm's in the bridge position.
Marco89
I have mine at 2, 3 mm away from the strings, so that can't be the problem.
My Gear,
Epiphone Sg
Sounds like the Nailbomb may be out of phase?
Marco89
The pickup is not out of phase, and it sounds like a humbucker should. It combines good with the neck pickup, but it's weaker than the stock gibson 490's. The 490's are not that powerfull, so I'm wondering if I did something wrong..  :(
The first time I changed my stock epiphone pups to Gibson 500t and 498r the shop made a mistake with the wires. A few months later I opened the guitar and discovered/corrected their mistake and the guitar was about 30% louder, and better sounding..
My Gear,
Epiphone Sg
fps_dean
This is wierd... the Nailbomb should be louder than a 498T and significantly louder than a 490T...  I don't get it...
Guitarzan
Make sure youhave a good solder joint.
My Nailbombs were fine for the first few days, but after beating around in my case a wire worked loose....not good for band practice!
The loosened wire was significantly quieter than the one that was soldered correctly. I'm guessing that a bad join has more resistance than a good join.
Hope that helps, not much of a guitar repairman myself.
Marco89
Oke guys, thanks for the response, I'll solder it again, hopefully it works better. You will hear from me soon.
thanks
My Gear,
Epiphone Sg
Marco89
Yeah :D  It worked!
Pickup is now a lot louder, sounds thicker and great harmonics & tone.. love it! Thanks everyone!
My Gear,
Epiphone Sg
Peter Antal
fps_dean
Nice.  Have fun with it.
Glad you got it working. I think I'm gonna re-wire my Mules some time as I've got better at soldering now, maybe they'll sound even better  :o
