Author Topic: pickup spacing  (Read 2937 times)
I_cant_play
pickup spacing
« on: September 26, 2006, 09:02:50 PM »
just getting ready to order a set of mules for my epi lp. I measured the spacing between the centres of the polepieces at the bridge pickup and it's 52mm. however the low e string is about 2mm "inside" the outer polepiece. which spacing should I order in this case?
thanks
Epiphone Les Paul Standard - Mules
Randall rg100sc
jasmine takamine classical
original crybaby
pickup spacing
« Reply #1 on: September 26, 2006, 09:16:32 PM »
a les paul should have 50mm spacing assuming it has a tune-o-matic
I_cant_play
pickup spacing
« Reply #2 on: September 26, 2006, 09:48:30 PM »
I rmemeber tim saying that that is not always the case. some newer les pauls apparently have 52mm....
Randall rg100sc
original crybaby
pickup spacing
« Reply #3 on: September 26, 2006, 10:01:12 PM »
oh really? i stand corrected! sorry about that
pickup spacing
« Reply #4 on: September 26, 2006, 11:10:20 PM »
The string spacing across the bridge saddles on your LP, or on a modern Gibson, is probably between 52 and 52.5mm, so over the bridge pickup it'll be about 51mm (older - much older - Gibsons would probably be narrower).
If you go for 50mm spacing, the strings will be towards the "outside" of the polepieces, with 52mm they'll be towards the "inside", so really one is as good as the other - take your pick!  Personally I prefer 52mm for the bridge and 50mm for the neck.
I_cant_play
pickup spacing
« Reply #5 on: September 27, 2006, 01:49:48 AM »
thank for the replies guys.
that said. I just ordered my first set of mules! very excited about this :)
I chose open coils with the bridge pickup black and the neck zebra. the pup's are gonna be unpotted too.
Randall rg100sc
original crybaby
