schecters...
Started by sambo, October 02, 2006, 05:08:32 PM
fps_dean
They start at $729usd and go up depending on options from there.   Mine seems to be all the stock options, so with alder, a maple neck, ebony fretboard, fixed strat style bridge and Sperzels on a DC127 it will run you about $800.
You can get some cool options too - stainless steel frets instead of standard Dunlop frets, which I'd recommend because they hardly wear (but they do rust eventually but if you play it enough they will still last you a lot longer).
Take a look at www.carvin.com and see what you like.  You can get a mahogany body and flame maple top for about $1000usd.  You can also get ash which I'd find tempting (partially because I have three alder body superstrat style guitars).... but that's straying away from the typical Les Paul sound, and some other woods you don't get the options for anywhere else like Walnut or Koa.   Great if you know what you want.
If you don't get a flame or quilted maple top, I would get a cool looking translucent finish however ;)
deg0ey
Quote from: fps_deanYou can get some cool options too - stainless steel frets instead of standard Dunlop frets, which I'd recommend because they hardly wear
I thought I read somewhere that they're bad for your tone though...
Sifu Ben
They do make it quite bright and tinny.
sambo
awesome dean! cheers for the info+site e.t.c... theyre reaaaaaaally tempting...
yours is a DC127 you say?
