Author Topic: Mississippi Queen split with push-pull  (Read 4144 times)
broken cord
« on: October 11, 2006, 09:58:03 PM »
Would one use a 250 or 500 pot for best results?
Warpig/Mississippi Queen
Calibrated Painkillers
Nailbombs
« Reply #1 on: October 11, 2006, 10:02:20 PM »
Not sure you can even get a coil tap (you can't split a single coil pup!) on a Mississippi Queen any more.
« Reply #2 on: October 11, 2006, 10:23:35 PM »
Quote from: TwilightOdyssey
Yes you can - I've got one on order!  Just specify an MQ with coil tap and three conductor wiring.
I'll be using mine with the standard Gordon Smith pot, so I've no idea what that is!  Gibson will have used a 300k or 500k pot on their P-90 guitars, so I'd go for a 500k.
OD-Black_Fire
« Reply #3 on: October 11, 2006, 11:17:32 PM »
You are thinking about coil splitting. That is when you have a humbucker and you bypass one of the coils to get a single coil sound.
A coil tap bypasses some of the windings for a lower output.  It can be used on single coils also.
broken cord
« Reply #4 on: October 12, 2006, 12:21:16 AM »
You can order a MQ with 3 wires for coil tapping, I was wondering what would work best with it. Stock is a 500k pot, single coils use a 250k.
Nailbombs
« Reply #5 on: October 12, 2006, 01:12:18 AM »
I've read that P90s work better with 500K because even though they're single-coils they have high inductance, like humbuckers.  Do I really understand what that means?  I do not.   :wink:
Must admit I've never experimented with 250Ks - I suppose they should make the P90s sound a little warmer.  Might have been a good idea on my old Hamer Special, which had quite harsh-sounding Duncan P90s.
broken cord
« Reply #6 on: October 12, 2006, 03:27:11 AM »
Well being that the 500k pots are already there I guess I will stay with them then; thanks for the imput. I guess if I feel I need to change the warmth I can always change to the 250k pot.
Nailbombs
Shag101
« Reply #7 on: October 12, 2006, 01:13:43 PM »
My queen neck got a 500k pot.  Im bringing it to the meet.
Warpig = '88 Charvel Model 1
broken cord
« Reply #8 on: October 12, 2006, 05:58:02 PM »
Quote from: Shag101
Excellant - That is the combo I am going to start off with for a Gibson SG. I have a couple of other guitars that will also be treated to BK's as soon as I sort out the funding.
Nailbombs
« Reply #9 on: October 12, 2006, 07:39:05 PM »
I have one with coil split, I used a 250K (I'm pretty certain, but I've had it for about  18 months so I might be wrong!).  But anyway you can listen to the difference the split makes.
deg0ey
« Reply #10 on: October 12, 2006, 09:28:40 PM »
Quote from: OD-Black_Fire
I think he was aware of that (knowledgeable man that TO) but there was talk a coupla weeks ago where it was mentioned (for some reason) that Tim won't tap an MQ anymore - although we know this to be incorrect :drink:
