Author Topic: Open Backed v Closed Backed Cabs  (Read 4827 times)
Elliot
« on: October 12, 2006, 11:56:45 AM »
What's the sonic difference?
Buddha
« Reply #1 on: October 12, 2006, 12:18:29 PM »
Typically closed back has more bass presence and a tighter feel. It' also makes the sound more directional and sound less 'open'. And open backed have a looser low end and less depth.
ToneMonkey
« Reply #2 on: October 12, 2006, 01:46:50 PM »
There's a lot of good info over at www.18watt.com might be a good place to have a look around.
Deadstar
« Reply #3 on: October 12, 2006, 04:51:03 PM »
Works on a similar principal as putting a subwoofer in the boot of your car (if you've got one try this - sit in the front seat and try the boot door both and closed you'll hear quite a difference) it's a bit like the way bass reflex ports work aswell (not exactly) basically the lower end of the notes you play are reflected back towards you and create a seamingly bassier response as the frequcies aren't dissipated out of the back of the cabinet. Type your question into a search engine I'm sure you'll find plenty of other forums giving you better answers.
"The secret to creativity is knowing how to hide your sources." -Einstein
