Electric misstress wiring c--kup - Help!?!?!
Started by Chris1974, October 15, 2006, 08:21:15 PM
Chris1974
I decided to carry out a series of mods on my electro harmonix electric misstress flanger pedal, the mods are from an article printed in Novembers edition of Guitar and bass magazine.
Whilst carrying out a mod on the filter matrix switch I made a c--k up and seem to have re-wired it wrong as the flanger circuit still works but when I slide the switch to activate the filter matrix it deactivates the flanger but I do not get the matrix effect , the colour control seems to be working but the range control isn't doing anything.
I think I re-wired the switch wrong when I was transfering the filter matrix switch to a 3 PDT foot switch, before I removed the wires from the original filter matrix slider switch I labeled all the wires so i wouldn't mix up which way they were connected but I think I've c--ked up some where.  Even after soldering the wires back onto the original switch the flanger is working but not the filter matrix.
So my question is does anyone out there have an electric misstress pedal - the older style with built in mains power supply ?
If so, would it be possible for them to open it up and suss out how the 6 wires are connected to the filter matrix switch by tracing them back from the various points that they exit the pcb ?  I know its a pain in the arse but if anyone cares to take pity on me and help out that would be a great help, I've already tried re-wiring it in different permutations but I think its  a lost cause !!
If I had an identical pedal to copy the wiring from that would be big help !
Kilby
Goodbye London !
Chris1974
nice one, I'll post a message on there and see what they say.
Kilby
Goodbye London !
Chris1974
no not yet, since I posted my question its been buried by like another million zillion questions (ok, slight exageration !) relating to pedals, I'll give it some time, someone will hopefully spy it and reply.
Surprised nobody else on here has offreded any advice although I guess its a bit specialised.
Will see what turns up.
Chris1974
I'm really annoyed with myself with the c--kup I've made as all the other mods. work fine !!!
pakalolo
hope this doc will help. It's a 9v Electric mistress layout I got on the diystompboxes forum.
pakalolo
Chris1974
Excellent, cheers for that, I will print it off and see if I can make any sense of it.  I'll let you know how I get on.
Chris1974
Quote from: pakalolohope this doc will help. It's a 9v Electric mistress layout I got on the diystompboxes forum.
Cheers for the diagram but it doesn't seem to correspond to my particular pedal, mine has 6 wires going from the circuit board to the switch, the circuit must have been revised over the years.
Cheers anyway.
pakalolo
Chris1974
Cheers mate that looks very promising, it has the 6 inputs to the switch and the rest of the circuit looks the same as mine.
I will give it a whirl tonight !
Did U get sorted as friend is lending me his to look at?
Chris1974
Quote from: sgmypodDid U get sorted as friend is lending me his to look at?
Yes I did thanks, the circuit diagram in the link was the correct one and I got my pedal working this evening................ cheers for your help anyway mate, I appreciate your efforts ! :D
Chris1974
Quote from: pakaloloIf it's a deluxe EM you should have a look at this
http://www.generalguitargadgets.com/diagrams/dmistlo.gif
Cheers for that link pakalolo............ you little beauty!  I rewired the switch and it works perfectly now   :D
I'm relieved that I've restored my pedal back to full working order.................  now to crack on and learn some of those Gilmour solos !!!  Thanks again, another result for the forum .
