Fulltone pedals powered from 18v
Started by Brow, October 16, 2006, 08:14:15 PM
Brow
Hey guys.
I just wondered if anyone's ever tried to power their Fulltone pedals (Fulldrive II or Fat Boost more specifically) from an 18v supply, and if so, how does it change the tone?
It's something I'd consider doing myself if it's worth doing, but don't really wannt to 'waste' the money on a new power adaptor for the pedals if it doesn't make too much difference :)
Thanks.
Craig
Brow
Quote from: TwilightOdysseyBattery power is always better.
Not when you have a pedalboard like mine it isn't!  :roll:
Dakine
why not wire two 9volt batts together for a 'cheap' trial  :P
Brow
Quote from: Dakinewhy not wire two 9volt batts together for a 'cheap' trial  :P
I could do I s'ppose. I think there's a schematic for that on the Fulltone website :)
Kilby
A lot of op-amp pedals indeed prefer 18V (or even 12V) as most op-amp based pedals are actually voltage starved.
Unfortunitely most users avoid pedals that require 2 batterys (check out the complaints in music mags, especially when it comes to active basses)
Rob...
Most transistor based fuzzes / distortion pedals tend to give their best sound when a zinc carbon battery is on it's last legs (hence theres actually flat battery emulation circuits around). How wierd is this pedal business going to get ?
Goodbye London !
Dakine
diagram? phewy!
Two bitsa wire and conect in series.
- to + to - to + or whichever way round it is in pedal, voila 18 voltys :)
