General Consensus- Coil Tap or Split?
Started by dave_mc, October 19, 2006, 11:05:45 PM
Hi guys,
I was just wondering, what's the general consensus on what sounds better in a twin humbucker guitar as an option for slightly cleaner tones- coil tap or split?
It'd be a Miracle Man bridge, Cold Sweat neck, by the way.
Thanks for any help!
:drink:
EDIT (for clarity): I suppose, at its simplest, my question is this: what's the difference in tone between a coil tap and coil split?
Don't get the question Dave.  A coil-split humbucker is when one coil is turned off to give a single-coil tone.  A coil tap (to my understanding) would mean taking out a "tap" wire part-way through the windings of both coils, leaving a lower-output but still humbucking pickup.  As far as I know, no-one has done this except Schecter on their old Monstertone pickups.  :?
Do you mean coil split vs. series/parallel?  Series/parallel gets my vote.  The parallel tone is usually very different from the series tone, especially with higher output pickups.  And it's still humcancelling.
blue
prs 513 has a reduced power tapped humbucker mode, although it does technically have 5 single coils rather than H/S/H.  i like the idea of tapped humbuckers, you could have a Les Paul that would switch between, say, a black dog and a stormy monday output.  obviously you can't do miracle man to stormy monday.
i can sense Tim rolling his eyes thinking "oh god, they're all gonna start ringing up asking about tapped humbuckers now" :roll:
Nah, Tim's too busy learning all those Iced Earth songs to worry about tapped humbuckers.  Over to Steve...?
I guess what I mean is, which sounds better, in your opinion:
getting the pickups tapped at 1000 (or whatever number is customary) less winds to still ensure humbucking operation?
or
just making do with a split, for semi-single coil operation (problem with this one is, they won't sound exactly like singles)?
for getting slightly cleaner (less gainy) tones, as those are pretty "metal" pickups.
it's for a custom guitar, by the way, I can get it wired whatever way I want (within reason, I don't want 50 million switches, lol). Oh, and just in case it's not clear, I fully intend to have series wiring (with full winds) as well, lol. I'll use a push-push knob to access the splits or taps. I just want them for a little extra versatility.
Thanks for the input so far! Now I'm off to get food... I'll be back tomorrow. :D
:drink:
I'd imagine it would sound like rolling down the volume pot only with the same tone? Probably wrong but its just a guess.
Kilby
Quote from: _tom_I'd imagine it would sound like rolling down the volume pot only with the same tone? Probably wrong but its just a guess.
With coil splitting, you get less mids, and the pickup sounds 'more' like a single coil.
From what has been said some pickups split better than others.
Rob...
Goodbye London !
ooh yeah I was referring to tapping the coil as opposed to splitting  :oops:
CaffeineJunkie
thas what i'd have thought, as the volume pot just reduces the output of the pup, which is why it cleans up the sound
OD-Black_Fire
Yeah Tim must be like "Oh what the $%&# do they want now?"
Coil ... what? Tapping or splitting the power of a humbucker?
LEAVE THE HALL!
RorySRV
Yea I'm confused as well.
So tapping a humbucker is reducing the power etc meaning less gain right?
And Splitting it is a switch that makes it 2 seperate single coils right?
BTW if you want to have a coil split option on the neck and bridge would it just be a question of pulling up the volume knob to activate the split?
Would you have to have a seperate push pull knob for each pickups?
And once split could you choose which pickup out of the 2 humbucker coils you used as a single coil?
So many questions  :P
RorySRV,
blue
well Rory, you can have seperate switches for each pickup or a single switch to do both, whichever you prefer.  and yes, it is possible to switch between the coils.  i have a Patrick Eggle Berlin with a three way rotary switch that does just that; in the middle it's a humbucker, turn one way you get the inside coil, the other for the outside coil.  and yes, a tone control would have been more useful :roll: .  there is very little difference between the two coils of one humbucker.
haha, that's what i get for making a new thread at 10.30pm when I'm tired! (EDIT: 10.05 d'oh!)
anyway, to clarify:
as far as I know you can either get a pickup wired for coil-splitting (4 conductor) which will turn off one of the coils of the humbucker to make it sound a bit more like a single coil, or you can get a coil-tap, which takes a wire out of the humbucker (both coils active, i.e. still humbucking) at less than full winds, to give you a tone with less gain.
My question is, if any of you have tried both options, which sounds better for a slightly less gainy tone for cleans and similar stuff?
I can get either, since it's a custom guitar.
I'm guessing the split will sound a little more like a single coil, but they never really sound exactly like a single coil since they aren't constructed the same.
:drink:
EDIT: I suppose, at its simplest, my question is this: what's the difference in tone between a coil tap and coil split?
Quote from: RorySRVYea I'm confused as well.
(a) So tapping a humbucker is reducing the power etc meaning less gain right?
(b) And Splitting it is a switch that makes it 2 seperate single coils right?
(c) BTW if you want to have a coil split option on the neck and bridge would it just be a question of pulling up the volume knob to activate the split?
(d) Would you have to have a seperate push pull knob for each pickups?
(e) And once split could you choose which pickup out of the 2 humbucker coils you used as a single coil?
RorySRV,
(a) yeah, i think so.
(b) yup, though only one coil will be active. It won't buck hum any more.
(c) yep, assuming you use a push-pull and not push-push knob (or some other device for activating the split). I think it's normally the tone knob that's wired to activate the split though.
(d) you can... it's up to you. it gives you more versatility if you have two, because that way in the in-between setting, you can have on pickup fully humbucking, and one pickup split. Depends what you want, of course.
(e) yeah, depending on the way you wire it.
:drink:
