Author Topic: Pickup spliting (humbucker to single coil etc)  (Read 2273 times)
Carlsuth
    • http://www.myspace.com/carlsuth
« on: October 31, 2006, 12:40:49 PM »
Hi, just a quick question really,
Has anyone used either a :blackdog set/Mule set/mule neck..blackdog bridge with 4 push pull pots?
I just want to get a few ideas (if people have done this) about if they sound as good as they do when used as the normal humbucker.
Any comments are welcome...
Thanks.
« Reply #1 on: October 31, 2006, 02:20:50 PM »
I've got a coil split Mule in the bridge of one of my guitars.  The single coils are very useable and I've chosen to have the screw coil as the split for the greatest difference in tone from the full humbucker.  The screw coil gives a clear and bright single coil tone, almost like a Tele bridge pickup.  The slug coil sounded more like the middle pickup of a Strat.
I use the split coil for cleaner arpeggio parts and it works great!
CaffeineJunkie
« Reply #2 on: October 31, 2006, 10:06:55 PM »
have a butchers at the players section (via the search function) and you'll see a couple of clips i posted a while back with a coilsplit Black Dog.. any others you want, lemme know and i will try to help out :D
Carlsuth
« Reply #3 on: November 01, 2006, 12:07:42 PM »
cheers for that guys.
Ill check out your clips right away! Thanks for your help.
