Wah Pedal
Started by samoth2, November 18, 2006, 08:49:50 AM
samoth2
Well, I decided getting a Wah instead of a Distortion pedal
But I never tried any Wahs so which ones are the best?
Thx in advance  :)
Kilby
Well I'm a complete fool for the Vox
Goodbye London !
markofled
If you can afford them the best wah is probly the ZVEX WAH PROBE
The BUDDA BUDWAH is ment to be really good as well!
I had a VOX CLYDE MACCOY and didnt like it really nasty wen used clean.
I've been through the whole 'boutique wah' thing.  The BEST imo was the modded wah I got from Stuart Castledine (www.wah-wah.co.uk) but a 70s Jen Crybaby will get you 90% there for around £60 on ebay.
:twisted:
Canadian Steve
I've bought a number of wahs including a Dunlop Crybaby 535Q, then had the pedal modified by Stuart Castledine (wah-wah.co.uk) then bought a Boss V-Wah PW-10 and also used my Korg Ax-30 G wah.  I sold them all and finaly settled on a Teese wah, which I liked the best - a bit more vintage styled than the rest.  I would go for the Picture wah or they also do a custom one called a Wheels of Fire wah, which I ended up getting.  If you're on a budget, there's always the Dunlop Crybaby Original, which I heard a guy playing last night at the beer festival in Belfast!
BKPS: Cryogenic Apache set, Mule set, Riff Raff, Stormy Monday.
Elliot
I like my Ibanez Weeping Demon
Dakine
Just bought a DB-01 CFH (again) but guess it's not ya 'normal' wah  :P
samoth2
Well.. I should probably post the styles I play..
It will mostly be used for Hard Rock/ Metal, but it's always nice with some versatility ;)
samoth2
Quote from: DakineJust bought a DB-01 CFH (again) but guess it's not ya 'normal' wah  :P
As long as it sounds good it doesn't have to be a "normal" wah :D
Antag
Morley Bad Horsie - best wah design ever & built like a tank.
samoth2
Quote from: AntagMorley Bad Horsie - best wah design ever & built like a tank.
I looked at it and it looks really great :)
Antag
I like the switchless design - you stand on the pedal & it turns on, take your foot off & it turns off - foolproof (Antagproof even :))
Plus the pedal is spring loaded to be fully "back", so the first sound is an "upward" wah rather than the "downward" one you get from a crybaby.
samoth2
But it's expensive to :(
Antag
Not much more than the original crybaby & a good deal less than some of the other models.
You can even get a Bad Horsie II for less than that....
I have a vox and an original crybaby both set up with different sounds using some of the mods Stuart Castledine does, he has two pages, one that sells parts and modified wahs and one page that shows you how to do the mods yourself:
http://www.wah-wah.co.uk/
And
http://homepage.ntlworld.com/s.castledine/greenfuz/wah.html
I hated wah pedals untill i did some of these mods!  Increasing the size of the sweep and doing the vocal mod really makes the wah easier to use and a lot less quacky.  Its really cheap to buy a basic vox or crybay and a handfull of resistors and stuff then experiment to find the sound you want!
