Help Installing Nailbomb - Trilogy Suite set
Started by WITH FULL DISTORTION, November 21, 2006, 03:07:15 AM
Hails Guys
i´m not understanding the wiring on this
i have a Nailbomb humbucker bridge and a trilogy suite neck single coil.
the nailbomb has one wiring coming from the humbucker. it´s with a braided shield of iron. or whatever you cal it.
and inside it, theres a .. shite, i can´t explain this. I think you know
i got mine with the 2 conductor.
how to wire it, since mine has only one wire?
or. i think i doing some mistake here
what should i do with that metal chain that embraces the humbucker wiring!?
and what to do with the wire cloth that embraces the wiring inside it?
i´m totally confused. ahahahaha
Sorry
my pickups doesn´t have the schematics. due to a specialpackage ben had to do for me.
Q:)
Hails
JP
Antag
You wire the braid (the outer metal shield) to the back of your volume pot - that's the earth.
Then the core wire to the pickup selector - just push back enough of the cloth cover to expose ¼" of wire to make teh solder joint.
Here is the wiring diagram that Tim sent me with one of my HSS sets.  Of course, this pic shows the wiring for 4 conductor.
It pains me to put this link on a BKP forum :) but this Duncan diagram shows the diff between wiring a 2 con & 4 con.
Hope this helps.
Thank´s Antag
i´ll try it as soon as i arrive home
i´m going to university right nOw
Q:p
Hails
JP
