Author Topic: nailbomb and mississippi queen combo: confused!  (Read 22686 times)
nick_24589
« Reply #45 on: December 05, 2006, 01:51:04 PM »
has anyone got any sound clips of them using a nailbomb or mississippi queen playing muse songs?  thanks
nick_24589
« Reply #46 on: December 07, 2006, 05:23:03 PM »
sorry to bug everyone again, this should hopefully be my last post on this topic. just wondering what part i measure to work out if i need 50mm or 53mm spacing and do i need conductor 4 or braided 2? thanks once again, after  i know this i can finally get them! i take it when you order the mississippi queen all you you have to do is choose the cover?
Kilby
« Reply #47 on: December 07, 2006, 05:29:10 PM »
Quote from: nick_24589
I'd suggest 4 conductor to allow you coil splitting options
as for the spacing there is a couple of threads, but they sum up to measuring the width yourself (to make sure)
Rob...
Goodbye London !
Antag
« Reply #48 on: December 07, 2006, 05:29:25 PM »
Measure the distance between the 1st & 6th strings over the polepieces of your existing bridge pickup.
You only need to get a 4 conductor humbucker if you want to have the option of coil-splitting.  However, you don't have to wire in coil splitting if you have a 4-con.
For the MQ, you choose whether it's for the bridge or neck position & what cover you want.
nick_24589
« Reply #49 on: December 07, 2006, 06:16:19 PM »
so you would recommend the 4 conductor? too be honest i don't have a clue what the difference is so im going by what you guys say :D  i have open poled pickups at the moment but don't have strings on the guitar, so i measured from the first silver screw on the pickup to the last silver screw and it measured at 50mm exactly, so i guess thats right
Antag
« Reply #50 on: December 07, 2006, 07:54:30 PM »
Get a 4 conductor & you can't really go wrong - you can either wire it for simple humbucker operation or to a coil splitting switch to allow you get get a single coil type sound as well.
Assuming that those pole pieces lined up OK when you had strings on it, then yes, 50mm will be fine.
nick_24589
« Reply #51 on: December 07, 2006, 08:25:04 PM »
thanks for the advice mate, i will get the options you advised
