Author Topic: JCM 800 2203 FX loop noisy because???  (Read 3046 times)
keano
« on: December 02, 2006, 03:55:51 AM »
Hi guys,
I have a 2203 JCM 800 reissue. Love it. I notice with the FX loop button engaged the sound thins out. Would a looper pedal solve this problem?
Is thinness caused by pedals in loop or just by engaging button?
If caused by pedals rack type FX unit could help right?
thanks
« Reply #1 on: December 04, 2006, 12:04:37 AM »
plug a patch lead between the send and return jacks then engage the effects loop.  if you notice a difference with just the patch lead between the send and return then it's gotta be the shitety effects loop that Marshall have put in the amp.
 :twisted:
keano
« Reply #2 on: December 04, 2006, 06:25:10 AM »
Turns out it is the pedals thinning it out. I know loop pedal would skip the FX when not used like you said. But sometimes I use reverb for rhythms so FX needed. Would a FX rack processor do less tone robbing on the bottom end?
Just need good delay and reverb options no tone loss. G-Sharp? Xpression?
