Author Topic: Which pickups?  (Read 3543 times)
Yoshi
Which pickups?
« on: December 30, 2006, 10:24:44 PM »
I play an Ibanez RG2570 (basswood) through a Carvin MTS tube amp. The stock Dimarzio/IBZ pickups are ok, but I desire something more. I play hard rock (with a little bit of metal). I would like a high output pickup that delivers the utmost possible clarity, and has loads of harmonics. I've looked at many Dimarzio pickups, and I am strongly considering the Steve's Special for the bridge, as I have heard of its harmonic and clarity abilities. I also looked at the Dimarzio X2N. However, I have browsed over Barenuckle pickups as well, and they are very expensive compared to the Dimarzios!
Which Barenuckle pickups would recommend for hard rock/metal music? As I said before, clarity would be my biggest priority. Also, how would Barenuckle pickups compare to the Dimarzio X2N in terms of clarity/output/harmonics? Thanks!
Crazy_Joe
Which pickups?
« Reply #1 on: December 30, 2006, 10:31:35 PM »
If you want a rival to the X2N, you should check out the Miracle Man, or maybe, if your feeling even heavier, the Warpig.
Miracle Man has a ceramic magnet with huge amounts of power and harmonics, very similar to the X2N.
Check out some of the clips in the players section.
The reason why BKP's are so expensive is because they are hand made, every pickup is made the same way, by hand. Top quality components and top quality performance is what you will get.
Black Dogs
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
Which pickups?
« Reply #2 on: December 31, 2006, 02:50:24 AM »
The X2N has so much power I don't think that clarity is it's strong point, maybe a ceramic warpig would give you similar levels but a much much better tone, for something a little closer to the steve's special would be the miracle man, but remember these are BKPs with their own sound not copies of dimarzio or any other brand.
All BKPs will give you clarity, it's one of their trademarks :)
I see a rainbow rising
Look there on the horizon
And I'm coming home
Which pickups?
« Reply #3 on: December 31, 2006, 03:12:37 AM »
The Cold Sweat will do everything you want.
Yoshi
Well...
« Reply #4 on: December 31, 2006, 03:27:46 AM »
lol, this is kind of funny. I was actually torn between the Warpig, MM, and Cold Sweat myself... Any further suggestions based on:
Hard Rock/Metal style
I'm thinking the MM...
Any suggestions would be greatly appreciated. :)
Crazy_Joe
Which pickups?
« Reply #5 on: December 31, 2006, 02:15:44 PM »
I don't think the Warpig would be similar to an X2N tbh, Miracle Man will give you all you want i think.
Black Dogs
Yoshi
k
« Reply #6 on: January 01, 2007, 02:15:16 AM »
How does a Ceramic Warpig compare with a MM? Thanks!
Which pickups?
« Reply #7 on: January 01, 2007, 02:56:08 AM »
The cWp will be too in-your-face. Go CS or MM.
fps_dean
Which pickups?
« Reply #8 on: January 01, 2007, 08:42:06 AM »
Quote from: TwilightOdyssey
^^ He said it... I was thinking Cold Sweats for you too.
