No harm would be done, in fact that is the exact set that Telecaster master Jerry Donahue uses. Also Rickenbacker guitars sell that combination as the 'correct' set for their six string guitars. If you go onto :
www.stringsdirect.co.uk/
and look under Rickenbacker strings, you will see that a Rickenbacker six string set runs:
10,13,17,24,32,42.
I have tried that combination on my longer scale guitars (Fenders) and it is a very nice combination. It especially sounds nice and clear on the Telecaster. I only changed back to 10-46 on Fenders because whilst I prefer 10 tops, I like to use readily available sets.
You may even like to consider the F150 set, still available from Dean markley and possibly GHS strings. That set runs:
10,13,15,26,30,38.
If moving away from 10-46 I prefered the balanced sound of 10-42s on Fenders though. On Gibsons I like the equal sonic/tension string balance across the neck that a 10-52 set offers, due to the shorter scale length.
Regards,
FF.
