Whammy bar retro fit
Started by stuckin93, January 01, 2007, 01:11:10 PM
stuckin93
I'm looking for a whammy bar that can retro fit onto a Gibson that currently has a stop bar & bridge.
the key thing is that it has to be a straight swap - no drilling or routing as i want to be able to put it all back if i need.
anyone know who makes these?
BKP's - Black Dogs...
...so far
gingataff
I see a rainbow rising
Look there on the horizon
And I'm coming home
stuckin93
...so far
stuckin93
OK now I'm probably just being thick - these replace the tuneomatic bridge part & the stop tail part just gets taken off  :?:  :?
...so far
gingataff
Looks to me that it replaces the stop bar, you still need the bridge. In effect I think its a little like a compact Bigsby.
And I'm coming home
It's probably a lot more expensive than those others, but the Stetsbar looks an impressive piece of engineering.  It's supposed to have a wide pitch range and stay in tune well.
blue
i have both the les trem and the stetsbar, and both work well.  the les trem is more bigsby like, it really only does gentle wobbles.  the stetsbar is much more sensitive, more modern whammy sounding.  both fit without having to do any drilling or routing.
stuckin93
Quote from: Philly QIt's probably a lot more expensive than those others, but the Stetsbar looks an impressive piece of engineering.  It's supposed to have a wide pitch range and stay in tune well.
It might be - but it looks the business! I think I've found my trem! :twisted:
...so far
stuckin93
I now need to start saving - £180 delivered!  :cry:
...so far
gingataff
I just found this pic on the Stetsbar webpage, looks like a set of BKPs in that ZW Epi!
http://www.stetsbar.com/gallery/Ians%20Epi.htm
And I'm coming home
blue
believe it or not, that's my guitar!!  i bought it off the guy that did all the modifications.  the only change i've made is to swap the skull knobs for chicken heads.
the pickups are crawlers, and the little black button is a kill switch.
blue
er, not ACTUAL chicken heads, they would be too slippy...
gingataff
And I'm coming home
Quote from: bluebelieve it or not, that's my guitar!!
That's mighty cool, Blue!
Is the kill switch one of those "momentary" off switches that lets you simulate the Tom Morello toggle-switch thing?
gingataff
Probably a switch that links the bridge pickup directly(ish) to the output jack. You can do the Morello/Rhoads/early EVH on/off easily with an LP just by turning the volume off on the neck pup and flicking the usual toggle.
And I'm coming home
