Author Topic: coil split for the dimebucker  (Read 6766 times)
BloodMountain
« on: January 02, 2007, 11:32:21 AM »
hi all
when i get my warpig for the bridge of my razorback, i will put the dimebucker in the neck.
i would like to coil split it though, and have the control over the splitting on one of the 3 pots: neck volume, bridge volume and a master tone.
i would like to know if you can:
1. use a pot as a coil split switch (push/pull). i know you can buy push pull switches for pots, but can you do it?
2. which pot would i use? the master tone or the neck volume?
thanks!
« Reply #1 on: January 02, 2007, 11:45:33 AM »
You'll need a push/pull pot for it to work but there's no reason why it won't.  I'd replace the neck volume pot.
BloodMountain
« Reply #2 on: January 02, 2007, 11:48:53 AM »
k thanks
BloodMountain
« Reply #3 on: January 15, 2007, 04:47:04 PM »
i have another question....
if the dimebucker was coil splitted while the guitar's volume knob is on 3, would it clean up more than before it was split?
thanks
blue
« Reply #4 on: January 16, 2007, 12:38:40 AM »
when split it'll have approximately half it's unsplit output, so yes, it'll clean up more.
BloodMountain
« Reply #5 on: January 16, 2007, 06:53:44 PM »
thankyou very much! that solves the problem of having a single channel head then!
BloodMountain
« Reply #6 on: January 16, 2007, 08:01:01 PM »
haha im actually really excited about doing it now because i would love a single coil sound! plus the Dimebucker is bright enough to make it sound even more like a single coil when split!
sorry about that pointless post  :D
ill restrain myself next time
