Do BKP's need rings or Rubbers.
Started by maverickf1jockey, January 05, 2007, 07:28:07 AM
maverickf1jockey
My guitar has no pickup rings, will i need to get them installed?
gingataff
How are you current pickups fitted?
I see a rainbow rising
Look there on the horizon
And I'm coming home
maverickf1jockey
gingataff
You may have some foam or rubber under your pickups to hold them steady so use that and mount the BKPs into body exactly the same as the ones you have now, no need for pickup rings :D
And I'm coming home
I had to adjust height of the pole screws of the Rebel Yell set for my Axis, as the screws were too long under the base plate to fit nicely when on body mounted. But after slight adjustment, it was fine.
One shitety thing: You might have to increase the size of the mounting hole in the pickup for the screws to fit. However, that will make it unuseable for ring mounting.
maverickf1jockey
bugger.
i want to avoid routing bits of the guitar as much as possible.
the rings will look better on it anyway, but i've heard they can get really annoying feedback problems.
i need to check whether i can actually fit the rings in the first place (i am not too sure if the neck pup touches the fretboard)...
Another thing to bear in mind - see how long the "legs" of your current pickus are.  BKPs are available with long or short legs.
maverickf1jockey
can i check that without taking them out.
do you mean the depth, or the tabs at the side?
Quote from: maverickf1jockeydo you mean the depth, or the tabs at the side?
The vertical part of the baseplate's metal tabs/legs (not the overall depth of the pickup, although that could also be an issue - coil and magnet thicknesses vary too).
I don't have BKPs here that I can measure, but a Gibson humbucker has long legs - about 1/2" - and a DiMarzio has short ones - about 1/4".  What are your current pickups?
You might be able to measure them without removing the pickups, depends on the guitar.
maverickf1jockey
Hmm, I don't know anything about Maverick pickups. :?
I looked at a couple of pictures of Mavericks and I don't think there's room for a mounting ring, the neck pup looks really close to the fingerboard.
I think it would be worth taking them out, doing a few measurements and checking with Tim and the guys before placing an order.
maverickf1jockey
yeah, but i just changed the strings and don't fancy restringing the floyd again.
Looking at Tim's Music Man the uncovered Pups would be compatible...
But i want a covered version, are they bigger?
A cover does make the pickup a little bigger - I had to do a tiny bit of routing to fit my Riff Raff in my SG.
It's not a big difference though.  Again, it'll depend on how they've routed your particular guitar.
I have a Miracle Man/Irish Tour directly mounted into the body of my Kamikaze 4 ... no pickup ring requred!
maverickf1jockey
good to know, that should save me a couple of pennies.
