Ceramic Warpig Pics (Problem Solved!)
Started by Crazy_Joe, January 05, 2007, 04:49:40 PM
Mister Crowley
Sounds like your Warpig is faulty and is of no further use.
Send it to me and I will dispose it for you :twisted:
Crazy_Joe
I'm not sure if it is right, just tried a screwdriver and this is what i got
Bridge: Neck pickup makes noise
Middle: Both
Neck: Pig makes noise
Black Dogs
edit- read your post wrong, I think the switch is just backwards
Quote from: Crazy_JoeI'm not sure if it is right, just tried a screwdriver and this is what i got
Middle: Both
Neck: Pig makes noise.
I know this sounds like a stupid question, so my apologies, but was the guitar working OK before you swapped the pickup?  It sounds like the switch is upside down (no big deal, I think that's how EVH liked his Peaveys wired).
You should only have had to un-solder then re-solder 2 connections to the bridge volume pot, there's no way that should have affected the function of the selector switch.
Crazy_Joe
So what exactly do i have to solder?
Black Dogs
Well, by the sound of it, nothing.  :?
Just to confirm, to install the pickup (it's 2-conductor, right?) you should have had to do 4 things:
1. Un-solder the old pickup's hot wire from the left-hand tag of the bridge pickup volume pot.
2. Un-solder the ground connection from the back of the same pot.
3. Solder the braided part of the BKP's cable to the back of the pot.
4. Solder the BKP's hot wire to the pot's left hand tag.
If you disconnected or connected anything else, then something's wrong.
Crazy_Joe
That is exactly what i did.
So why do i have a mutant super human middle position which sounds suspiciously more warpig than my bridge position.
Black Dogs
Quote from: Crazy_JoeThat is exactly what i did.
That's what it sounded like you did.
QuoteSo why do i have a mutant super human middle position which sounds suspiciously more warpig than my bridge position.
No idea!   :?  :wink:    Unless it's some strange consequence of the fact that in the middle position you have a super-powerful ceramic pickup combined with a vintage-output (I assume) alnico pickup.  It's possible the pickups are out of phase, but that would normally produce a bright-but-hollow sound, not something huge.
It's not really possible to wire a 3-way toggle switch to select the bridge pickup in the middle position, or vice versa.  The switch doesn't work that way.  And you can't have accidentally shorted a coil of the WP, because it's only 2-conductor.
Maybe the bottom line is that the Ceramic Warpig just doesn't sound the way you expected.  Either that, or it's faulty.
Crazy_Joe
I think i need it looked at by a professional, to see if everything is right.
Black Dogs
BloodMountain
the WP should have plenty of bass and output - something isn't right here.  have you checked the wiring against a wiring diagram?
here's a diagram to check it against... http://www.seymourduncan.com/support/schematics/2h_2v_1t_3w.html
:twisted:
Crazy_Joe
Me and _Tom_ have decided Tokai are gay and have put my switch backwards, it is pretty clear what has happened, because everything i think is right is the opposite on Tom's. So my perception of a bridge humbucker and a neck humbucker have been completely reversed.
Black Dogs
Quote from: Crazy_JoeSo my perception of a bridge humbucker and a neck humbucker have been completely reversed.
You mean when you listen to the bridge pickup you think you're listening to the neck pickup?  Does that mean the CWP is OK after all?
Tricalibur
That is the most beautiful thing I have ever seen... Can't wait to get mine!!! :]
<The Warpigs Are Coming, Hide your Children... and bring BBQ Sauce>
Crazy_Joe
Yeah the Warpig is amazingly huge!
I always thought a bridge humbucker sounded like a neck and a neck like a bridge. Well done Tokai!
Black Dogs
