does the Ceramic Warpig clean up well?
Started by metal mitch, January 07, 2007, 06:06:13 PM
metal mitch
if you roll the volume down, does she clean up?  not jazz clean, but clean enough, say for song intro type stuff?
Crazy_Joe
Not really :lol:
But i don't think it was made to do that really.
Black Dogs
BloodMountain
yeah, it was made for all out BRUTALITY!!!
im going to use my neck humbucker with volume down and coil split for cleans, that is, when i get my ceramic warpig...  :x
need more money!!!  :)
You have to back it right off for a clean sound. But when you do its pretty good, yeah. Certainly not my first choice for a clean, but its useable live, say.
Crazy_Joe
It also depends on what wood it is in.
Black Dogs
BigK
Im Hijacking a little here but does anyone know what the ceramic warpig is like either coil-spit or in parallel?
PRS Tremonti - PRS Silverburst 594 - Ibanez RG550EX, RG570 & RG721FM - LTD SC 500 -  Schecter 006's - EVH 5150III 50w into custom Zilla Vert 2x12
Davey
parallel... i'd say it would clean up a bit...
but why would you need clean from a pickup that's brutality impersonated?
Mines wired for series, split and parallel.
Parallel, it opens up a little, compresses less, has good cleans, takes the edge off the gain, but is still harder hitting than most pickups in series. Really articulate shred tone. I like this one.
Series is still aggressive for a single sound. Quite full, too. Still has a little difficulty cleaning up, but is obviously the easiest.
metal mitch
thanks for the replies
Quote from: Daveybut why would you need clean from a pickup that's brutality impersonated?
well, I dug out a mahogany Explorer body and neck that I ordered from Warmoth about 4 years ago when I was going through a "I wanna sound like Hetfield" phase.  I forgot I had those damned things!  for some reason I ordered the body with a single humbucker route at the bridge, so I guess I was looking to get Metallicrunch and clean outta one pup?
a ceramic Warpig is definitely going in there.  if it doesn't clean up, no big deal.
gingataff
Quote from: metal mitchthanks for the replies
If you add a 3 way switch for series/parallel/coil-split it will give you lots of choice and the split will let you get much cleaner, it'll be like a hot single coil. Stick on a bit of chorus and you're there.
I see a rainbow rising
Look there on the horizon
And I'm coming home
