German amps
Started by LazyNinja, January 10, 2007, 09:23:14 AM
LazyNinja
Would amps from Germany work in the UK? As in the voltage and the pin shape etc.
yeah well you'd need a british power supply.
LazyNinja
Ok, so do I just need a british power cable but not an external transformer or anything? Thanks
gingataff
I'm prepared to be proved wrong but most amps have a switch between 110/230 volt use, and if not then most of Europe uses 220v and the UK uses 240v. Consequenty pretty much all electrical appliances sold in the EU are rated at 230v so that they work with both. You will of course need a UK plug on the end of your lead though.
I see a rainbow rising
Look there on the horizon
And I'm coming home
Lord Blakers
Yep, as above - you just need a kettle lead with a 3 pin uk plug on it. Ask the IT department at your workplace; they'll have hundreds of the buggers.
BKPs: Warpigs, VHIIs, Holy Diver, Juggernauts
Quote from: LazyNinjaOk, so do I just need a british power cable but not an external transformer or anything? Thanks
yeah, you need a british plug/power supply/kettle lead.
