November 19, 2026, 11:37:59 PM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
At The Back
The Dressing Room
BASS DRUM MUTING
BASS DRUM MUTING
Started by BloodMountain, January 15, 2007, 04:50:45 PM
Previous topic
Next topic
Print
Go Down
Pages
1
2
User actions
BloodMountain
Welterweight
Logged
BASS DRUM MUTING
hi everyone
do you or the drummer in your band know how to mute a bass drum to make it sound really muted, like really plastic-y? if you don't know what sound i'm talking about, listen to some recent Dimmu Borgir or some Pantera
thanks everyone
Welterweight
Logged
BASS DRUM MUTING
#1
January 15, 2007, 05:02:54 PM
stuff all ur bedcovers in there. pillows, duvets, whatever.
BloodMountain
Welterweight
Logged
BASS DRUM MUTING
#2
January 15, 2007, 05:09:27 PM
we stuffed my brother's (my bro is the drummer) pillows (all 3) in there, but it doesn't sound the same AT ALL.... it just made the sound a bit more muted, but not enough.... there must be another way...
Richie Zero
Junior Flyweight
Logged
BASS DRUM MUTING
#3
January 15, 2007, 05:10:47 PM
There's a good chance that there's a lot of compression added afterwards. That may be the key rather than anything you can do to change the pure acoustic sound.
sambo
Welterweight
Logged
BASS DRUM MUTING
#4
January 15, 2007, 05:11:16 PM
there probably is another way but i think a fair amount of it must come from the micing up of the drum and/or the mixing of it in recordings.... and perhaps the drum itself.
i know that playing our drummers bass drum through a mixer+P.A and tweaking the settings gave it a much more muted sound...
Guest
Logged
BASS DRUM MUTING
#5
January 16, 2007, 04:20:49 PM
Your drummer needs to use plastic beaters on his kick pedals. There is also a plastic disc you can add to the beater side of a kick drum to get that type of attack. Shell type has a lot to do with it. A blanket is suffient to dampen the kick but don't overdo it.
Also, tune the beater side and shell side of the kick drummer differently from each other; this will drastically alter the tone of the kick drum.
zigmund
Flyweight
Logged
BASS DRUM MUTING
#6
January 16, 2007, 05:28:59 PM
Stuff the drummer in the duvet, then stuff the duvet in the bass drum.
Evens out the mix nicely.
zigmund
Flyweight
Logged
BASS DRUM MUTING
#7
January 16, 2007, 05:30:11 PM
"Compression", we calls it.
Davey
Welterweight
Logged
BASS DRUM MUTING
#8
January 16, 2007, 05:34:30 PM
LMAO
good one
BloodMountain
Welterweight
Logged
BASS DRUM MUTING
#9
January 16, 2007, 07:04:59 PM
haha i wouldn't though, hes crazy... he would attack me!
thanks everyone, thats good advice, ill get him to try that lot.
TO, we were looking at those plastic kick pads in a shop, and we weren't sure what it did to the tone... thanks for telling :D
Deadstar
Bantamweight
Logged
BASS DRUM MUTING
#10
January 17, 2007, 11:08:45 PM
As everyone else said.
EQ: The 150Hz - 500Hz tends to need a slight dip as well as narrower notches around 800Hz and 1.3kHz. For that Pantera sound theres usually some high end slap to accenuate the attack around 7kHz - 9kHz (I think)
Also try letting the pillow/duvet or whatever your using touch the rear skin (ie- the one thats not being "kicked")
Could also try using a noise gate (sparingly.) Please not drummers hate this when its on its own but it does clean up the mix a little in context.
Hope that helps. If in doubt make him get a better bass drum.
"The secret to creativity is knowing how to hide your sources." -Einstein
Middleweight
Logged
BASS DRUM MUTING
#11
January 17, 2007, 11:30:17 PM
Another good way to mute the kick drum is to hide the drummer's pedal-renders the kick drum totally mute.
nfe
Welterweight
Logged
BASS DRUM MUTING
#12
January 18, 2007, 02:24:44 AM
Dimmu Borgir kick sounds are usually triggered like nobodies business and all Vinnue Pauls drums are gated beyond belief.
Bit of EQ as noted above will get good results. His technique also has a fair impact.
Just don't go down the horrid wooden beaters and 50p's route :lol: :lol:
Deadstar
Bantamweight
Logged
BASS DRUM MUTING
#13
January 18, 2007, 09:59:00 AM
oh yeah, you don't mention how you mic the drum up
, this makes a lot of difference. Even the height placement, mic type, two mics, etc...
steve
Lightweight
Logged
BASS DRUM MUTING
#14
January 19, 2007, 12:13:40 AM
Tape a old credit card from the top onto the bass drum just where the pedal makes contact. So the drum actually hits the card,make sure the credit card in taped only from the top so it can move away from the drum slightly. This will give you the click you are after, its an old studio trick. If it does'nt work dont blame me im not a drummer!!
Print
Go Up
Pages
1
2
User actions
At The Back
The Dressing Room
BASS DRUM MUTING
User actions
Print
