Author Topic: P90 Style Pickup Adjustment  (Read 12877 times)
chrisheyes
« on: January 16, 2007, 12:15:23 AM »
I've just dropped a BKP92 into my Tokai Les Paul Special
Can anyone offer advise on how to adjust the pickup height on these P90
style pickups so that I can get a better ballance with the neck pickup.
At present the pickup screws directly to the body.
Should I put some packing under the pickup to raise its height or raise the individual pole pieces ?
Cheers
« Reply #1 on: January 16, 2007, 08:36:03 AM »
I'd do a combination of both.  Raise the pickup first, and if you need more height pull the polepieces out a tad.
« Reply #2 on: January 16, 2007, 12:28:49 PM »
Gibson used to use a foam pad under the bridge pickups in the early guitars. In later models they made the rear pickup sit higher with a spaced inside the pickup.  BK make copies of the original pickups, so you will need to add a foam pad underneath.  The other thing you can do is put the Strat pickup tubing around the mounting screws before you put the pickup into the guitar.
I have a friend who always screws the pole pieces out a lot to compenstate, but I really don't like this look and prefer to pad the pickup to raise it.
« Reply #3 on: January 16, 2007, 12:44:58 PM »
Off topic Chris, but is that a TonePros bridge or a Pigtail?
chrisheyes
« Reply #4 on: January 16, 2007, 12:55:22 PM »
Quote from: Philly Q
Well spotted Pilly Q - It's a Pigtail
chrisheyes
« Reply #5 on: January 16, 2007, 12:58:46 PM »
Thanks for the advise PhilKing & Twinfan
I'll give putting some compressible material under the pickup.
At present the bridge pickup is way too much  treble/top in comparison
with the deep woody Gotoh LP-OLD stock neck pickup.
« Reply #6 on: January 16, 2007, 01:08:31 PM »
Quote from: chrisheyes
Well spotted Philly Q - It's a Pigtail
Thought so!  :D
They're excellent bridges, I've got one on an SG and one on my Melody Maker.  The TonePros looks almost identical but the Pigtail's much lighter.
« Reply #7 on: January 16, 2007, 01:15:57 PM »
The P-92 is a hot BKP-90, so I'm not surprised it's very different from the neck pickup......
chrisheyes
« Reply #8 on: January 17, 2007, 01:37:03 PM »
Quote from: Twinfan
It's different in a unexpected way - Lower output than the neck and considerably brighter than the pickup it replaced
ToneMonkey
« Reply #9 on: January 18, 2007, 10:19:51 AM »
Out of curiosity, could you tell me how deep the routes are in your guitar.  I'm just about to route for P90's in a guitar that I'm building and I'd like to double check my measurements.  Cheers mate.
chrisheyes
« Reply #10 on: January 21, 2007, 08:04:19 PM »
Quote from: ToneMonkey
Bridge pickup = 16mm depth
Neck pickup = 20mm depth
