TSL100 vs. JCM800 clips here!
Started by keano, January 21, 2007, 08:38:26 PM
keano
I am a obsessive moron idiot. Always comparing shite and feel like wasting time usually. Never the less this is my latest obsession. I have both of these amps here and did a ton of tests. TSL is good because it can do low volume recording 25 watt VPR. So I did some tests with the 25 watt on and off against the JCM800. I got to return one in a few days.
Please download the zip and tell me what you guys think. My $%&#ing ears are bleeding. Try to keep in mind not to favor the "louder" clips.
It is a blind test! Each folder contains a similar riff. Out of those folder you pick the one you like best.
ex:
A - 4
B - 8 and so on
Thanks for feeding the obsession!
http://media-creations.net/clips.html
Metal comparison coming soon!
To be honest matey, we're talking pretty subtle differences here aren't we!
For me, the ones that just had a bit more clarity (and therefore got my vote) were:
A - 15
B - 18
C - 5
D - 5
I must admit, I had to listen to everything several times to make a choice.
keano
Thanks for the time. Yes I expected bigger differences but your right subtle differences. You choices are interesting. 2 were same exact amp and setting. Other two the TSL. I will post answers later and winning amp.
They sound like they could be the same amp.
B is the most little different. Were I to guess I'd say thats the 800, the first one sounds 800 and the last two also sound TSL, but like I said: I get the impression you could get those sounds out of either amp.
I dont really have a strong prefference.
Bring on the metal test!
keano
Hi MDV actually each folder contains both amps with some tweaked settings some with a OD infront of JCM.
So you gotta pick your fav out of each folder. Some that sound very similar are actually same amp but one with hot plate.
JamesHealey
A, 12
B, 17
C, 5
D, 4
are my favourites.. what do i win?
In that case I cant hear anything like a significant difference, at least on what I'm listenning to it on, and shant comment.
