TSL 100 vs. JCM800 2203 metal clips
Started by keano, January 23, 2007, 07:02:59 AM
keano
Just wanted to compare TSL VPR against the 100 watts of each. What sucks is I am not making music any more all I f**king do is make clips lately and can't stop. Depressing seriously. Anyway playing is cr@p timing is off but I am burned out and one take is all I am gave it. So take a listen.
These are the high gain clips. Same thing blind test just your favorite out of the folder.
Thanks for feeding the obsession!
Each folder contains a similar riff. Out of those folder you pick the one you like best.
ex:
A - 4
B - 8 so on
http://media-creations.net/clips2.html
keano
more marked differences this time.
favourites are:
1 from group A
10 from group B
16 from group C
keano
thanks. so far A is  clear winner from this and other forums. Debate on C still
genocidal tendencies
I can't get the page to load, is that just me?
keano
Peter Antal
Canadian Steve
BKPS: Cryogenic Apache set, Mule set, Riff Raff, Stormy Monday.
keano
Thanks guys answers are:
A.
1. JCM800 Hot Plate -4, Vol. 2.5 w/SD-1 Keeley 9-11-12
2. TSL in 25VPR mode, Vol.3, Gain 8
3. Same as 3 but with ZW-44 OD.
4. TSL full 100 watts. Gain 8 Vol 2 used clean boost on solo
7. Same as #1 but with HP-8 and vol. 3
B
8. Same as 3
9. Same as 2
10. Same as 1
11. Same as 4
12. Same 1 BUT using MXR EQ +6 +6
C
16. same as 3
17. same as 2
18. same as 4
19. same as 1
Peter Antal
Seems like people preferred the JCM800 this time. Nice thread! 8)
keano
Also posted this at MArshall amp forum and Seymour Duncan forum. and results were A-1, B-10, C-18 had edge and 19 close behind.
