Author Topic: annoying buzzing  (Read 5037 times)
matteo
annoying buzzing
« on: January 24, 2007, 09:45:23 AM »
just noticed something wierd? my amp buzzes when position 1,3 and 5 selected on the pickup switch but its ok in position 2 and 4?? i just thought it was my amp buzzing as i only really use pos 1 and 5!!!
the guitar is a yamaha rgx420 with 2 vhIIs. any ideas??
thanks
Mr Ed
annoying buzzing
« Reply #1 on: January 24, 2007, 12:04:54 PM »
A 5-way pickup switch on two humbuckers? How is it wired? Do you have any of these positions set as coil taps?
annoying buzzing
« Reply #2 on: January 24, 2007, 12:59:17 PM »
Typically it should be the other way around, as positions 2 & 4 are usually the coil splits.  Depending on the switch though, it might be a PRS style wiring, in which case 2 & 4 might be HB with different coils from both pickups.
You need to look at the switch to see how it is wired.
matteo
annoying buzzing
« Reply #3 on: January 24, 2007, 03:07:43 PM »
position1 = both coils on neck pickup
position2 = both coils in paralell
position3 = all 4 coils from both humbuckers
position4 = the front cil from each pickup
position5 = both coils on the bridge
it also has a direct output switch that bypasses the tone, volume and pickup switch and runs the bridge flat out. (very handy :twisted: )
maybe just a duff selector?
thanks
annoying buzzing
« Reply #4 on: January 24, 2007, 07:39:20 PM »
Which colour wire did you put to each tag?  The VHII is an offset coil humbucker, so it is not completely silent, but then you would hear it in all 5 positions.  When you say pos 4 - front coil from each pickup, is that the screw coil from 1 and the slug from the other?
matteo
annoying buzzing
« Reply #5 on: January 24, 2007, 08:03:37 PM »
its the screw pole in the neck and the slug from the bridge. the screws are on the outside of the pickups if you know what i mean. thats the way the standard pups were in so im sure they are round the right way!
also i forgot to say when i touch the strings the buzz goes away. (bad earth?) when im playing it sounds fine but as soon as i let go you can ear the buzz. im only bothered as it only does it on some 1, 3 and 5 so i know its not right?
guess ill just have to keep playing :P
matteo
annoying buzzing
« Reply #6 on: January 24, 2007, 08:04:36 PM »
by the way what do you mean by an offset coil humbucker??
thanks
