gordon smith..tone bleed?
Started by sgmypod, February 06, 2007, 01:05:11 PM
HAve a graduate slimlin ...with very weird wiring how do I tell sound wise if I have a tone bleed on?
edit forgot to say has a funny tone pot 0 8 normal 9 10 fully open
Mr Ed
If you have it set to 9-10, shouldn't the sound be a little bit brighter?
Mr Ed
Erm, I'm confused... is it that you can't actually hear a difference?
no not sure if I have the treble bleed circuit..gor
don smith wiring is weird, so wondered what It should sound like if I have one(don't want to undo any wiring as would find hard to put back, they have 2 leads going to the live on the tone pot from each vol/ push pull pot)
Put the tone pot fully 'on' with the guitar plugged into your amp and the amp switched on.
Roll the tone pot back slowly and as it gets to 9/10ish you should hear a slight "click".  This is the tone circuit kicking in.  As you say, when the pot is fully on the tone circuit is bypassed.
There's also a treble bleed capacitor on the volume pot to retain the highs as you roll back the volume.
cool that explains a lot...like why I have 4 capacitors in there, doesn't the tonebleed kill the tone..sure I i've read tim say that?
