Main Menu
two E#?
Started by Toms' anominous, February 23, 2007, 12:17:02 PM
Toms' anominous
ok i so got a problem with my cheapo telecaster when it turned up in the mail.
on the Bstring at the 17th fret it makes and E# and at the 18 fret it makes an E# but the 16 is a D and the 18 is supposed to be an E# so how can i fix it?
Must make the best guitar ever!!
maverickf1jockey
you may have a low or high fret. does it affect just that one string?
Toms' anominous
yeah just that one string and just there which is funny because the natural harmonics are fine.
Adnd i know theres no real such thing as E# its F (just for the hairsplitters)
Your 18th fret is high relative to the 17th
It may be loose in its slot and need pushing back inand glueing in place
then a quick levelling of that area would be a good idea too
A small localised fret dress is what i would prescribe - plus having the 18th fret secured as described above
May be worth having a tech look at it
Toms' anominous
ok thanks alot for the help i think it might be more of an action problem though cos they look about the same hieght
Quote from: Toms' anominousok thanks alot for the help i think it might be more of an action problem though cos they look about the same hieght
You wont be able to tell unless you lie a small straight edge over 3 frets (17/18/19) and see if it rocks back and forth
Have someone look at it if you are unsure
Toms' anominous
ok ive just used a straight edge and it appears that the 15th, 16, and 17th frets are lower then the rest. So its not a question of having the 18th fret too high but the other three too low. damn i'm gonna have to buy a new neck and swineheads not BKP now :(
Quote from: Toms' anominousok ive just used a straight edge and it appears that the 15th, 16, and 17th frets are lower then the rest. So its not a question of having the 18th fret too high but the other three too low. damn i'm gonna have to buy a new neck and swineheads not BKP now :(
Effectively the same thing though - the 18th sits higher relative to the ones below it
It may well be rectifiable , but will probably cost you to have done
Depends on the value of the guitar whether you see it as worth it
Toms' anominous
nah i'll get my grandad to deal with it as he's very good with wood and what not, and i trust him cos he's fixed loads of previus guitar problems.
Quote from: Toms' anominousnah i'll get my grandad to deal with it as he's very good with wood and what not, and i trust him cos he's fixed loads of previus guitar problems.
that's excellent news - handy to have someone who can do that sort of thing in the family
