Author Topic: Silly question I know...  (Read 2383 times)
Sailor Charon
« on: February 25, 2007, 07:55:13 PM »
but do the coils of a two coil pickup have to be right next to each other, or can there be a small gap?
[I ask, because the pickups on Mylene's bass are, now I look again, oddly spaced. They seem to be J-type pickups (by their length) and are layed out as a wider one at the bridge (possible humbucker/paired coils?) the other two aren't so much middle and neck as neck and very close to neck - there's maybe a coil's width between them. And I was wondering whether they might be parts of the same pickup...]
Muzzzz
« Reply #1 on: February 26, 2007, 10:05:12 AM »
Dunno.
 :D
{Insert witty signature HERE}
« Reply #2 on: February 26, 2007, 01:28:08 PM »
The coils of a humbucking pickup normally have to be right next to each other (or stacked) because they share the same magnet(s).
I think you need a pair of single-coils for your neck/middle pickups, but if you wanted you could create a "humbucker" by having one of the pair reverse-wound/reverse-polarity and wiring the pair in series.
Sailor Charon
« Reply #3 on: February 26, 2007, 04:28:59 PM »
Quote from: Philly Q
Thanks.  It's not going to be an issue for a while. I just wondered because of the general lack of identifiable controls - I noticed that bass guitars sometimes don't have pickup selectors, and rely on adjusting the volumes... and there didn't seem to be enough dials/knobs for 3 pickups...
One other question, why doesn't there seem to be the same variety of bass pickups as guitar pickups? (Lower sales?)
« Reply #4 on: February 26, 2007, 06:14:46 PM »
Quote from: Sailor Charon
Well, no offence to whoever draws Mylene, but I suspect he/she has little or no knowledge of guitar construction.  You might have to be a bit creative to make your bass work properly.  Maybe use concentric pots so you have two knobs in the place of one?
Quote
Well, there are quite a few different bass pickups available - look at Seymour Duncan's site for example.
Again, no offence - this time to bass players - but (with exceptions) it's not a lead instrument, it doesn't need to cut through a sound mix like guitar does.  And I don't think there's so much scope/necessity for tinkering with a bass tone, you don't really need different basses for different musical styles.  James Jamerson played a Precision, so does Steve Harris.  It's just... bass.
Don't shoot me, bassists...
Sailor Charon
« Reply #5 on: February 26, 2007, 07:43:19 PM »
Not sure who it was who'd have  been responsible for her bass, but I think you're probably right....Actually, I'm sure that if he had been he'd not have used such eccentric tuners. :) [The character designer would be Haruhiko Mikimoto, wheras the mechanical designer was Shoji Kawamori. I think it would have been one of them.]
I'm sort of guessing that the two round features on the lower part of the body are pots, with a pair of concentric ones (volume?) and a seperate single one (tone?)  And, of course, in 204x they no longer need output jacks...
Anyway, thanks for the help and advice.
