Splawn Competition doing Yngwie/Gilbert metal
Started by JamesHealey, March 05, 2007, 10:26:08 AM
JamesHealey
http://www.soundclick.com/jameshealey/
Splawn Jam, also another clip up there using the Splawn.
Stock Ibanez V8 and V7 pickups.. nothing fancy but the amp makes up for it.
Getting some new pickups soon anyway, yea I know this isn't BKP but check it out and im not using BKP's webspace, which I know is against policy.
steve
JamesHealey
that's the vai bit from the g3 96 vid/dvd, right? nice! where'd you get the tab (assuming you didn't make it up yourself?)?
:drink:
Peter Antal
Both clips were real fun to listen to. :) The Vai clip sounds HOT! (edit)
JamesHealey
I figured that vai thing out by ear, sorry no tabs guys.. it's not the same as the record by a long way but it's full of the main ingredients that made that solo special to me anyway..
The Vai solo was recorded exactly the same way as the other clip just not as loud, and a bit of delay was added at the mix down..
^ ah, ok. wasn't a bad work out then, if I could distinguish it!
:drink:
