Bright Pickups
Started by dave1221, March 06, 2007, 01:56:12 AM
dave1221
My friend recently ordered a Ceramic Warpig and Alnico V Cold Sweat for his bridge and neck pickups (respectively). He had them put into this RG1527 and found them to be excessively bright. We, as him and I are in the samre band, have been trying to find some solutions to this problem, but have yet to think of one. I have heard that he should change his pots to 250k instead of 500k, but would that really make a big impact on his tone? I am thinking that there was something wrong with the way the pickups were installed, but I am not sure. All help will be greatly appreciated...
-Dave
Oh, he plays through a Mesa Single Rectifier head with a matching cab, if that helps any.
Muzzzz
Not surprising, RG's are naturally bright guitars... Would adjusting pickup height solve this? I really don't know... :oops:
{Insert witty signature HERE}
Neemo
First check that the pickups have been installed correct. If they're fine then you could try 250k pots as they will lower the output slightly and tame the highs.
slow music for slow people
JamesHealey
BKP's are bright by nature due to the scatterwinding process it's a matter of personal taste, BUT! changing the pots will make a difference and might just land you in the right tonal park.. worth a ago as it's dead cheap to do.
metal_god
if they are so bad i think i might take them off your hands hehe :wink:
steve
I would'nt say bright, clear and defined maybe.
Make sure that you dint just copy the Dimarzio colour code to instal
the pickups would be out of phase with themselves and sound thin and bright and a bit "Yuk" too!
Tim
Ditto on that-check your wiring first. RGs are bright but Warpigs aren't, they have a really thick tone.
As a very quick check you can wire either pickup direct to the jack socket-red to hot, black and screen to ground.This way you'll hear the pickups in their natural state without going near the pots/switch etc.
Tim
everton_fc
I've been wondering that BKP seem fairly bright. Didn't realise until reading this thread that scatterwinding produces a bit more brightness.
