The only way you'll get a true DC reading is when the pickup is not connected to anything.Use a good multimeter, set to ohms, and read across hot and screen on braided hook up or red and black on 4 con.
Taking a reading off a jack or from the control cavity will not give a true reading as pots/cable etc all add resistance.
DC13K vs DC9K...............aha the great DC res mystery!
DC res is only a very rough guide to output and then only on pickups wound with the same gauge
wire.So a VHII for example wound with 42 AWG plain enamel @DC9.2K can easily sound as loud as an Emerald DC13.1K wound with 43AWG-the reality is the number of turns between the two isn't that different but the combination of wire gauge, wire tension and coil size/shape produces a quite different tonal response from each pickup.
