What pots are in my LP classic?
Started by JonnyScaramanga, March 25, 2007, 11:53:08 AM
JonnyScaramanga
I know that many Les Paul classics are fitted with 300k pots as standard, but is it all of them?
I took the back off the guitar, hoping the pots would be usefully labelled, but no such luck. It's a Gibson Les Paul Classic Plus bought new in London in April 2000.
I'm fitting Mules, so I suppose I'll need 500k pots with those for best results.
Bare Knuckles owned: Mules, VHII, Rebel Yells, BKP-91, Strat 63 set, Riff Raffs.
I think Gibson fit whatever they have in stock at the time.  I'd fit top spec 500k pots if I were you.  That's what I'll be fitting to my LP with Mules and what I have in my SG with Riff Raffs.
pretty sure that my classic+ had 300k pots.  defo put some 500k pots in there, 300k is too low and muddy (unless the pickups are VERY bright)
:twisted:
JonnyScaramanga
Is there an easy way I can find out what's in there? I don't want to waste £32 on new long-shaft pots if the ones in there will do. I've always found the existing controls on the guitar work really well.
They should say on them somewhere - maybe under the solder?
Quote from: JonnyScaramangaI've always found the existing controls on the guitar work really well.
Keep 'em then.  Just my opinion, but I don't see the point changing things just for the sake of it.  You can always replace them later if the Mules sound muddy.
get a DMM (multimeter) and measure the resistence of the pots if you want to be sure.
:twisted:
JonnyScaramanga
I've had an email from Gibson which says that it has 300k volumes and 500k tones.
I'm a bit in two minds about it really... The current pots do work perfectly with the 500T and 496R, but those pickups couldn't really be more different from the Mules. I guess I'll whack 'em in there and see how they sound.
Theories about pot values seem to vary a lot, but I've read in some places that 500K pots are more "necessary" with higher-output pickups than lower-output ones.
On that basis, if the 300Ks work OK with the powerful 500T/496R combo, they should be OK with much more vintage-output Mules.
My understanding was that 250K pots in strats are used to compensate for overly bright single coils, but to keep treble content in HB guitars, it's better to use 500K pots.
I mean that's just what I heard, it doesn't mean that I actually understand why, so someone more capable should comment.
If that was true however, I would be wondering whether the mules might lose some of their clarity/crispness when used with 300K pots.
gingataff
I've read that Allan Holdsworth used (not sure if he still does) 250k pots with humbuckers, but I think his tone is mostly about midrange with less emphasis on bass and treble.
I see a rainbow rising
Look there on the horizon
And I'm coming home
And I think it used to say on the Duncan website that Seymour's personal preference was 250K with humbuckers or single-coils.
I can't find it now though.  It's probably somewhere in his 17 million FAQs.
Alex
I've read a couple of times, that 250Kohm can smoothen out the top end if desired. So it's probably a matter of taste. Imagine a trebly humbucker in a bolt-on superstrat. Maybe people would like to tame the top end.
