what's the difference?
Started by Tarzan, March 25, 2007, 04:56:10 PM
Tarzan
sorry for my ignorance, but what difference does the type of magnet make to the sound of the pick-up? until i joined this forum, about a week ago, i didn't even know that there was more than one type of magnet.
plastercaster
I am going to be very naughty and link to the SD site
http://www.seymourduncan.com/support/faqdescr.shtml#magnets
Like everything seymour Duncan do this graph is absolutely rubbish  :wink: , because It only shows AII, AV, and Ceramic.
There is another thread discussing magnets about somewhere
Edit: here to be precise
bear in mind everything else in a pickup affects tone: Riff Raffs and Warpigs all use Alnico V, but they sound rather different I'd Imagine.
Another Edit:
Quote from: TimHistorically they're graded by no as they were introduced starting with a generic low grade Alnico.As the 50's progressed the other grades II,III,IV and V were introduced. AV was developed by the military and was the last to be introduced into the 'public' domain.
Yes they do all add to the character of a pickup although it must be understood that a magnet doesn't have a sound on it's own, it contributes by the way it powers certain frequencies. Alnico II is the softest and generally has a smooth bass and treble although this is more pronounced the hotter the windings get.Alnico III is very transparent, low output and clean,sounds great for rounded fat jazz applications, Alnico IV is probably the best vintage tone IMHO and along with II and III was used in the earliest PAFs-this is a fact  and not myth as we've had them analysed and a collegue of mine has also seen original Gibson purchase orders that clearly state AIV bar stock being purchased.The tone of AIV is balanced and extremely organic, it produces the most authentic vintage tone and sits better in slightly hotter vintage winds than AII which tends to get very mushy if used incorrectly. Finally AV is the hottest producing more highs and lows, great for rock applications or where power and cut are important.
Different companies use different grades for personal reasons, we use all of the applicable Alnico grades to suit the correct design, both to be historically correct but more importantly to have the best sound.
Changing magnets in a humbucker can give dramatic results, you soon find the ones that really don't sit right and others that are head and shoulders better.Obviously you can't swap out single coil magnets as they're integral to the coil form.
I've personally spent alot of time voicing all the BKP range with the correct magnets but I do tweak and swap sometimes on consultation with a customer with a specific requirement.
Orange rocker 30
VHII and Mississippi queen
Tarzan
